AutoCAD 2010/2011/2012
Active Member
wkoehler3
Message 1 of 12 (268 Views)
Why is this happening?
268 Views, 11 Replies
10-10-2012 05:18 AM
Over the past few weeks I've had a problem recurring and spreading through my drawings.  When I select a block I get a symbol I've never seen and the block will not copy or move where I snap.  It's as if there is some sort of offset in place.  And once an "infected" block touches another, it the next one has the same problem.
I've attached a screenshot of the unknown symbol.
Can anyone tell me what this is and how I get rid of it?
Distinguished Contributor
pkolarik
Message 2 of 12 (260 Views)
Re: Why is this happening?
10-10-2012 06:01 AM in reply to: wkoehler3
That almost looks like the "constraints" symbol? I don't use them at all, so don't know anything about them. Maybe look into turning constraints off?
Active Member
wkoehler3
Message 3 of 12 (249 Views)
10-10-2012 06:07 AM in reply to: pkolarik
That is what the symbol looks like, but there are no constraints on these blocks.
imadhabash
Message 4 of 12 (244 Views)
10-10-2012 06:13 AM in reply to: wkoehler3
it's a PARAMETER item , usually used to locks elements in position.
Please mark this as the solution if it resolves your issue.Kudos gladly accepted. ⇘
Active Member
wkoehler3
Message 5 of 12 (240 Views)
10-10-2012 06:20 AM in reply to: imadhabash
But we've been using these blocks for years over 10 years.  Why would they suddenly have parameters attached to them?  They aren't there when I first insert the block.  And I can have 2 copies of the same block, one has the problem, the other does not.
And the biggest question, how do I stop this from spreading to all the other blocks in the drawing as it seems to be doing?
JDMather
Message 6 of 12 (231 Views)
10-10-2012 06:40 AM in reply to: wkoehler3
Do you have Infer Constraints turne on?
Also, notice that it is not necessary to paste to Word.doc save doc attach doc, download doc, open doc file.
Simply paste to MSPaint and click the Insert Image link above.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Active Member
wkoehler3
Message 7 of 12 (223 Views)
10-10-2012 06:49 AM in reply to: JDMather
Infer is off.  New issue added on.  Now I select one item to move, but several items move along with it, not to where I said to move, and at different angles.  This is driving me slowly mad!
JDMather
Message 8 of 12 (221 Views)
10-10-2012 06:51 AM in reply to: wkoehler3
Can you attach an example file (*.dwg) here that exhibits this behavior?
Infer Constraints is off now - was it always off?
Active Member
wkoehler3
Message 9 of 12 (212 Views)
10-10-2012 07:01 AM in reply to: JDMather
Here you are. It seems to start with the items in red.  The indicated block is one of the problem ones
f.lawton
Message 10 of 12 (204 Views)
10-10-2012 07:13 AM in reply to: wkoehler3
Try the delconstraint command
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
