AutoCAD 2010/2011/2012
New Member
JohnnieBlount1890
Message 1 of 9 (491 Views)
Why is cad so slow?
491 Views, 8 Replies
04-06-2011 01:38 PM
I'm running MEP 2011 and Revit 2011.  My pc has a quad Xeon process, 16 gig ram, Ati Firepro v7800 video card.  I'm thinking it would be lightning fast working in files that are from 50 to 100 meg.  Is there a setting in Autocad to get maximum speed out of it?
Distinguished Contributor
borikg
Message 2 of 9 (488 Views)
Re: Why is cad so slow?
04-06-2011 01:48 PM in reply to: JohnnieBlount1890
what additional softwares installed on your PC? i mean engineering
*Expert Elite*
TravisNave
Message 3 of 9 (481 Views)
04-06-2011 01:57 PM in reply to: JohnnieBlount1890
Are you working on files over a network or with lots of xref files on the network?  Are you using a certified video driver?
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
*Expert Elite*
rkmcswain
Message 4 of 9 (466 Views)
04-06-2011 02:45 PM in reply to: JohnnieBlount1890
What specifically is so slow about it?
Opening and saving?
Is the cursor sort of "sticky" as you move it?
Are there certain commands that respond slowly?
Does it behave the same if you use a different Windows profile (i.e.: log in as a different user, preferably one who has never logged on to that machine before)
Does it behave the same if you disconnect all network connections (including unplugging the network cable and kill all wifi connections)
borikg
Message 5 of 9 (461 Views)
04-06-2011 03:10 PM in reply to: rkmcswain
in my case, Inventor is much faster than Acad. i concluded that if you want to work at optimal way with serious engineering software install only one such on you PC.
also i think Revit and Acad should be avoided to isntall on same workstation. all these dll fiels and registry modifications that each apps do create real mess on you working station.
borikg
Message 6 of 9 (459 Views)
04-06-2011 03:11 PM in reply to: borikg
if there is suggestion on how to accelerate opening of apps, let me know. might be there are files that are uploaded in this process and can be set to off.
New Member
JohnnieBlount1890
Message 7 of 9 (417 Views)
04-07-2011 05:33 AM in reply to: JohnnieBlount1890
It is slow when zooming in and out, during regens.  I have the files locally on my pc not on the server. No xrefs just equipment that has been loaded into the Revit file.  I wasnt sure if there were some settings in options that I could change to make the programs use the power and performance of my pc.  Im looking for faster results from MEP and Revit.
*Expert Elite*
TravisNave
Message 8 of 9 (398 Views)
04-07-2011 08:31 AM in reply to: JohnnieBlount1890
JonnieB,
Make sure you are running the certified video driver for your card as recommended by Autodesk:
http://usa.autodesk.com/adsk/servlet/cert/details?siteID=123112&catID=16303594&id=16391880&suite=100...
-or-
http://usa.autodesk.com/adsk/servlet/cert?siteID=123112&id=16391880
*Expert Elite*
Bob_Zurunkle
Message 9 of 9 (393 Views)
04-07-2011 09:15 AM in reply to: TravisNave
Search the forums for similar topics and you may find an attachment called Speed Up AutoCAD. That has some useful stuff that may help your situation...
If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted :smileyhappy:
Announcements
Need installation help?
