I use the dimspace command a lot. That's why I would like to set the dimspace variable to 0 instead of 'auto'. How can I do this?
[ The subject line of this post has been edited for clarity by @handjonathan Original: Where to set dimspace variable to 0 ]
Ok, that's what I want. But how?
Can somebody write the Lisp code for me please? I now how to load it then.
Thx.
According to Help:
Auto:
Calculates the spacing distance automatically based on the text height specified in the dimension style of the selected base dimension. The resulting spacing distance is twice the height of the dimension text.
DIMSPACE is not a system variable. It is a actual number you specify to space your dimensions out
You will need to find someone that knows VBA to code that for you. But I doubt that it will do what you expect... But have a look at it.
Here is some links on DIMSPACE
http://www.youtube.com/watch?v=ZXBByoozLZI
http://www.youtube.com/watch?v=sTrLskBXn9g
@JoAnn
I know that it isn't a system veriable but as it takes 'auto' as default value I think it must be possible to set this to 0 somewhere. But where...? 🙂
Ill try to write my own new command in lisp. If it works, I'll let you know!
I see that you live in South Afrika. I've been there last summer (winter for you). Beautiful country btw.
I've never used dimspace so I can't really attest to whether or not it's a sysvar. But even if it's not, it's got a command line option which should allow the autolisp function "Command" help you.
Try pasting the following into acad to see if it works -- it should set dimspace to 0 and you can use whatever value you want. If it does, then paste it into the acaddoc.lsp file as Dean suggested.
(command "dimspace" "0")
Here' a link to the documentation on dimspace.
Don Ireland
Engineering Design Technician
I can't find this anywhere. How to change the default to 0. But try the lisp file thing.
Sorry for the double post. But I just thought of this.
When you get it to have a lisp that sets your DIMSPACE to 0. Be careful that it does not prevent you from changing to a different value when needed. So for example. When you do a horizontal dimension and want to align the different dimensions it will be great. But when doing a vertical dimension, it might add all the dimensions on top of each other.
READ THE WHOLE THING!! after all.... i took the time to type it...the least you can do is read it! it's worth the time, and SHOULD solve your problem with the AUTO option in the DIMSPACE command in AutoCAD. After extensive searching, and countless hours of trial and error.....lots and lots of error....this is
the FULLY FUNCTIONING lisp routine that I came up with in order to get the DIMSPACE command to be default to 0 and not ask you for a set distance. Which is what I wanted for my personal use. I have absolutely NO idea how it works, or why, i cannot explain lisp to you, all i know is that this little gem is a huge time saver for me. feel free to modify the "CX" to what ever suits you. i used that simply because i was running out of options to try. i then went into my customization file and edited my .pgp file where you set your shortcut keys and set the keystrokes to "AD" so the .pgp entry looks like this:
AD, *CX
of course, you can set it to whatever you want. i wish i could be of more help as to explaining the HOW it works, but all i know is that it works for me in AutoCAD 2017. I hope it works for you as well as it does for me. to put this into AutoCAD (at least the way i did it, i know there are other ways)
As i said before, I'm sure that there are other more effective ways of doing this process, but this is what i've come across and it was written for people by people (me) that don't know $h1T about lisp programming. All i can say is that i personally haven't had any problems with it. and....YES!! you can still use the default DIMSPACE command and input a distance that you want or if you choose to go with the AUTO option it will space the dimensions to 2X the text height by default. OH! and one more little tid bit of happy fun times...YES!! you can use window selection to pick your dims that you want to move down to the BASE DIMENSION.... a problem that some other lisp codes i tried would not let you do. i'd like to be all cocky and act like i knew what i was doing...but that just isn't the case. if you copy the lisp BELOW THE LINE (if i have to tell you not to copy the line....) (>_<) then maybe you shouldn't be doing this at all....just sayin.... 😉
anyway...that all being said...feel free to copy, share, modify as you see fit. If you figure out a way to make it work better... awesome...I'd love to hear it. but i don't need any snotty emails about my crappy programming skills... I ALREADY KNOW! 🙂
this post was not written in response to just any one post, it's just the culmination of several hours and days of scouring the interweb for an answer to this issue. and i wanted it out there in case i need it again. I would actually rather see AutoDesk just implement a command like the AMDIMALIGN command that is in AutoCAD Mechanical, into ALL of the AutoCAD variations and alleviate this situation altogether... ...hint...hint...
(DEFUN C:CX ()
(Command "dimspace" pause (setq ss1 (ssget)) ss1"" "0.0"))
I'm actually looking for that answer today and figured it out myself today. My dimension style is annotative and using automatic dimension auto lisp but, the dimension space overlaps with each other or very far for some instance. The solution is you need to be unchecked the annotative, change the value of "Use overall scale of" then check the annotative again.
DIMDLI (System Variable) Controls the spacing of the dimension lines in baseline dimensions.
