AutoCAD 2010/2011/2012
JamaL9722060
Message 1 of 7 (187 Views)
What sort of constraints that may achieve this behavior?
187 Views, 6 Replies
03-06-2012 01:40 PM
In the screenshot below, I need to have symmetric behavior. For example, in case I stretch the indicated part of the drawing then I need the other corresponding part is to be stretched accordingly.
What constraints settings might achieve this?
The drawing is attached
Thank you for the help,
Best
Jamal
Jamal NUMAN, GIS and Civil Engineer, MSc
e-mail: JamaL9722060@yahoo.com
P.O.Box: 731, Ramallah, West Bank, Palestine.
Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
Windows 7 (Ultimate 64 bits),
Firefox 20.0,
Kaspersky 2013.
Distinguished Contributor
zzz144
Message 2 of 7 (184 Views)
Re: What sort of constraints that may achieve this behavior?
03-06-2012 02:26 PM in reply to: JamaL9722060
use the equal (=) constraint
you need to use the constraint dimenstions.... not regular dimensions
see attached...
JamaL9722060
Message 3 of 7 (172 Views)
03-06-2012 03:59 PM in reply to: zzz144
thank you for the help zzz144.
the issue now is: if i change the dimension to be 2.5, then regular diemension doesn't change accordingly!
best
Jamal
Firefox 20.0,
Kaspersky 2013.
zzz144
Message 4 of 7 (170 Views)
03-06-2012 04:10 PM in reply to: JamaL9722060
ah yes... you will have to redimension... because the true dimnesions lost their associativity...
just be careful how you dimension...
see attached.
JamaL9722060
Message 5 of 7 (167 Views)
03-06-2012 04:20 PM in reply to: zzz144
then in this simple case, much more manual work is still needed!
why ther is no way to let the regular dimesnion responds automatically?
there should be a way. otherwise, the parametric is not useful.
what do you think?
Firefox 20.0,
Kaspersky 2013.
zzz144
Message 6 of 7 (164 Views)
03-06-2012 04:35 PM in reply to: JamaL9722060
well you are sort of correct. autocad is not meant to be parametric. this constraint and parametric dimesnions are simply a little experiment/addon they built in just recently... and it has its bugs...
manual dimensions will obey the drawn geometry for as long as they can....
whereas the parametric dimensions when they cannot obey the geometry they simply cease to exist.
JamaL9722060
Message 7 of 7 (149 Views)
03-07-2012 03:27 PM in reply to: zzz144
Thansk ZZZ144. i'll try to post this issue in a separate thread.
best
Jamal
Firefox 20.0,
Kaspersky 2013.
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
