I've attached the file.
My goal: to create a block that I can use a Lookup Table to modify various parameters, and then after that, stretch out the block in a couple directions, and then have the ability to switch Lookup table option without issue.
Problem: When I use the Lookup table, choose 1, then the stretch both directions, AND then use the Lookup table and choose 4.....the block comes out as a funky angle.
My confusion: The parameters work fine seperately, I can modify them every which way, but as soon as they're in that Lookup Table, That rotation parameter becomes a pain. If i can modify the paramteres individually without issue why can't the Lookup table.
