AutoCAD 2010/2011/2012
JamaL9722060
Message 1 of 20 (3,200 Views)
What is the most efficient way to draw a line inclined by
3200 Views, 19 Replies
04-17-2012 12:59 PM
What is the most efficient way to draw a line inclined by particular angle from another line?
I wanted to draw a line inclined by particular angle from another line but couldn’t get the best way to do that.
For example, in the screenshot below, I wanted to draw a line inclined by 60º from an existing line but couldn’t approach the best way to approach it.
How can I draw this line efficiently?
Thank you for the help
Best
Jamal
Jamal NUMAN, GIS and Civil Engineer, MSc
e-mail: JamaL9722060@yahoo.com
P.O.Box: 731, Ramallah, West Bank, Palestine.
Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
Windows 7 (Ultimate 64 bits),
Firefox 20.0,
Kaspersky 2013.
Distinguished Contributor
Message 2 of 20 (3,179 Views)
Re: What is the most efficient way to draw a line inclined by
04-17-2012 06:42 PM in reply to: JamaL9722060
Jamal, there may be newer drafting aids to accomplish this task, but I would Array the existing line 120 degrees and then draw a Circle with the requisite length of the line as its radius, Extending or Trimming it to get the correct length.
*Expert Elite*
Patchy
Message 3 of 20 (3,171 Views)
04-17-2012 08:55 PM in reply to: dbanaszak
There is No newer drafting aids to accomplish this task.
Use snapang
Valued Mentor
Message 4 of 20 (3,162 Views)
04-18-2012 02:24 AM in reply to: Patchy
or usb x axis lines up with the first line  in the xy plane  and draw the second at 60 degrees
Valued Mentor
Message 5 of 20 (3,160 Views)
04-18-2012 02:57 AM in reply to: parkr4st
i mean ucs, usb. :smileyhappy:
dave
Valued Mentor
Message 6 of 20 (3,143 Views)
04-18-2012 07:37 AM in reply to: JamaL9722060
If you know the lengths and angles you want, why not just type it in from the command line?
Line command ► Select start point ► @ x" < x°
Don't end the line command there, but just keep going by entering more distances (@) and more angles (<).  If you're not effecient with calculating angles on the fly in your head, though, then it may not be a good solution.
________________________________________________________________________________________________
System specifications: AutoCAD 2015 64-bit, Windows 7 64-bit SP1, Intel Core i7-2600K, AMD FirePro V4900
16GB RAM, Crucial M4 SSD, 3 Dell Monitors (2 30" 2560x1600 & 1 20" 1200x1600)
*Expert Elite*
GrantsPirate
Message 7 of 20 (3,129 Views)
04-18-2012 08:42 AM in reply to: JamaL9722060
I prefer rotating the UCS (as mentioned earlier), I have UO set to UCS, Object, pick the object and start drawing.  I have UW set to UCS, World to get back.
Once the UCS is set, start the line, snap to the endpoint, you can use Polar at this point or type <55, enter, then specify length, among other methods.
Tip - you can set the angle increment angle in Polar to 1 if you want, or 0.5, etc, you don't have to use the predefined angles.
Message 8 of 20 (3,121 Views)
04-18-2012 11:48 AM in reply to: JamaL9722060
Patchy, I wasn't sure if anything new had been added to accomplish the task, and I tend not to mess with UCS unless I'm doing 3D work - I was formerly a Civil designer but it's been three years since I've slung a vector in anger to earn a paycheck. I'm back in school and HAD to take a graphics class (easy A) to satisfy pre-eng requisites. The solid modeling and the Inventor stuff has been fun, unfortunately they don't teach Civil3D. I asked questions earlier and am paying it back where I think I can be helpful, but don't be afraid to overrule me, I only think I know everything.
JamaL9722060
Message 9 of 20 (3,114 Views)
04-18-2012 12:22 PM in reply to: dbanaszak
Thank you guys for the contribution and feedback. Your comments are quite helpful.
Best
Jamal
Firefox 20.0,
Kaspersky 2013.
Active Contributor
CSEnginuities
Message 10 of 20 (3,099 Views)
04-18-2012 05:31 PM in reply to: JamaL9722060
Adjust your Polar Tracking settings from "absolute" to being "relative" to the last line drawn.
Clara
"A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools."
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
