AutoCAD 2010/2011/2012
Active Member
jessetherrien
Message 1 of 7 (507 Views)
Vports: Modelspace Disappearing
507 Views, 6 Replies
06-28-2011 10:15 AM
I'm having a little problem with the modelspace in a vport disappearing on me.
I am trying to do some B.O.M. work, and sometimes I can't snap to a particular point/object, so I turn osnap off and zoom in to identify the correct object. After a certain point in the zoom the drawing regens and then the modelspace disappears completely.
I tried a regenall, closing the drawing and starting it up again, but it's still not there. I checked the properties and it still says it's a vport. When I double click it to enter modelspace from the vport it doesn't take me into modelspace.
I've checked my maxactvp, that's maxed out at 64. I've run an audit and that didn't work.
Wondering if anyone else has encountered this problem and if you have a solution.
Jesse T.
Edited by
Discussion_Admin
Jesse T.
AutoCAD Civil 3D 2011 32-bit
Win XP Pro SP3
Dual Core, 4 GB of RAM
NVIDIA Quadro FX3700
SugarCAD
Message 2 of 7 (503 Views)
Re: RE: Vports: Modelspace Disappearing
06-28-2011 10:39 AM in reply to: jessetherrien
What is your graphics card and driver?
Active Member
jessetherrien
Message 3 of 7 (491 Views)
06-28-2011 11:13 AM in reply to: SugarCAD
NVIDIA Quadro FX3700 and the driver version is 6.14.12.7061
Jesse T.
Win XP Pro SP3
SugarCAD
Message 4 of 7 (482 Views)
06-28-2011 11:38 AM in reply to: jessetherrien
Latest Driver Try another driver, you can always rollback.
Is it just this one drawing? I had similar problems when on XP, but mine would be resolved by closing the drawing and reopening, though only temporarily. This particular problem went away after new computer, card and Win 7.
Active Member
jessetherrien
Message 5 of 7 (465 Views)
06-28-2011 12:08 PM in reply to: SugarCAD
I've updated my driver and we'll see if that works.
Sadly it's happening when I do that with most drawings.
Jesse T.
Win XP Pro SP3
Active Member
jessetherrien
Message 6 of 7 (454 Views)
06-28-2011 12:40 PM in reply to: SugarCAD
I also just noticed there is an option in the properties box in the misc section. It's an 'on' or 'off' toggle... and my vports were set to off :s
I switched it to on and the vport is back to normal...
Jesse T.
Win XP Pro SP3
Active Member
Message 7 of 7 (318 Views)
Re: Vports: Modelspace Disappearing
03-06-2012 11:07 AM in reply to: jessetherrien
question back to you for your clarification: not sure if we have the same problem that you indicate your remedied. When in paperspace, when zooming, my viewport content disappears depending on position of zoom. Sometimes regen helps, mostly not. You indicate go to <properties> box, <misc> and turn ,<on>. Question, which properties box from what command?
thanks.
Jim K.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
