Greetings everyone,
This is an AutoCAD 2011 related question about being unable to see under properties objects that I have attached to polylines in AutoCAD Map3D.
I have created an map3d .dwg that the polylines and points have attributes attached (objects). However, when I access the same file in plain AutoCAD nothing appears under properties.
Is is a format, import settings tweak or simply it can not be done?
Thank you in advance.
Solved by Murph_Map. Go to Solution.
Object Data is a Map3D function and only available with Map3D or Civil3D. That includes viewing it in the property palatte. Might look at Dotsoft Mapworks.
