I am unable to see the dimensions that I measure using power dimensions as per the attachment on the drawings itself. If i want to see it, I have to select the green line, and right click and select the line and select standard as the dimension style. I did not have to previously do all of this.
Appreciate the help!
Hi.
The forums are having a small issue with attaching dwg files. If you need to upload a drawing, try putting it inside a zip file.
Also, if you are using AutoCAD Mechanical, you'll probably recieve the best answers if you post in the AutoCAD Mechanical forum
