AutoCAD 2010/2011/2012
Active Contributor
Message 1 of 9 (827 Views)
Accepted Solution
Unable to Hatch
827 Views, 8 Replies
02-13-2013 03:40 PM
Can anybody hatch this pool deck with sun chairs (blocks)?  I have included an attachment ......triming here is very tricky if not impossible.....
*Expert Elite*
Patchy
Message 2 of 9 (813 Views)
Re: Unable to Hatch
02-13-2013 06:27 PM in reply to: bluebull
Different Z
Active Contributor
Message 3 of 9 (794 Views)
Re: Unable to Hatch
02-13-2013 09:35 PM in reply to: Patchy
Was this on on dwg?   it a 2D dwg...........what happened?
*Expert Elite*
Alfred.NESWADBA
Message 4 of 9 (785 Views)
Re: Unable to Hatch
02-13-2013 11:54 PM in reply to: bluebull
>> Was this on on dwg?
It IS in your dwg, open it, use _ORBIT to rotate the view and you see it.
Someone used other Z-values than 0, who did that or what command was used to create that is not stored in the drawing.
However, when I open your drawing AutoCAD tells me "DWG file was saved by an application not developed or licensed by Autodesk", so what have you used to create/modify this drawing?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
*Expert Elite*
braudpat
Message 5 of 9 (765 Views)
Re: Unable to Hatch
02-14-2013 06:41 AM in reply to: Alfred.NESWADBA
Hello
I hope that I have corrected all your strange Elevations !
Please check the DWG ...
Bye, Patrice
Bye, Pat
Active Contributor
Message 6 of 9 (749 Views)
Re: Unable to Hatch
02-14-2013 09:45 AM in reply to: Alfred.NESWADBA
           What a mess, I got this dwg from somebody else, did not tell these me of these  parameters ....
This one  is lost,  no wonder I could not succeed.
No more futher commets.
Lets move on.......
Valued Contributor
Message 7 of 9 (719 Views)
Re: Unable to Hatch
02-15-2013 04:04 PM in reply to: bluebull
I don't have time to open the dwg, but based on the other comments, it's worth mentioning: if you're not looking straight down on a hatch (for example, either the hatch is skewed relative to the Z coordinate OR the view isn't perpenticular to the hatch) then you can get unexpected results. For instance, often the hatch won't show up.
DDVPOINT set to plan (assuming the hatch is in the World x/y plane) is one thing to check.
Active Contributor
Message 8 of 9 (712 Views)
Re: Unable to Hatch
02-15-2013 05:01 PM in reply to: Kevin078
            Thank you very much, this bit of info. was an eye opener, I did not know about this command DDVPOINT it definite make sense........
The problem is that sometimes there are too many people working on the same dwg. and problems are created without anybody aware of it, and without knowing where to start looking, you assumed the file is corrupted.
Valued Contributor
Message 9 of 9 (650 Views)
Re: Unable to Hatch
02-19-2013 09:22 AM in reply to: bluebull
Understood. It can be like that sometime. - Playing detective can be a challenging part of the job. - By the way, if that was the issue the command FLATTEN may be of some use. A word of warning though, for very large dwgs FLATTEN (All) can take a while and/or cause ACAD to not respond. So, be sure to save your work first and you might want to FLATTEN portions of the dwg at a time.
For what it's worth, when ACAD says "Not Responding" sometimes it's just thinking (slowly). I've never seen this in any of the books, but doing a CTRL-ALT-DEL to the Windows Task Manager, highlighting ACAD and cancelling out of the Task Manager (DO NOT END TASK) can give ACAD a kick in the pants (& it'll start responding again).
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
