AutoCAD 2010/2011/2012
Active Member
Message 1 of 7 (404 Views)
Trim + Shift
404 Views, 6 Replies
03-14-2012 07:57 AM
Inside the trim command I cannot hit "shift" to switch to the extend command instead.
any suggestions?
GrantsPirate
Message 2 of 7 (401 Views)
Re: Trim + Shift
03-14-2012 08:04 AM in reply to: CMcKeeRUE
You must hold the Shift key down while picking on the object.
Active Member
Message 3 of 7 (399 Views)
Re: Trim + Shift
03-14-2012 08:08 AM in reply to: GrantsPirate
Yes I have done that but nothing happens.
Active Member
Message 4 of 7 (397 Views)
Re: Trim + Shift
03-14-2012 08:11 AM in reply to: CMcKeeRUE
It may be a system variable issue.
i can't seem to select anything if holding down the shift key in other commands as well.
(similar post - cant toggle ortho mode with the shift key anymore - ortho comes on but i can't pick a point)
*Pro
nestly
Message 5 of 7 (394 Views)
Re: Trim + Shift
03-14-2012 08:17 AM in reply to: CMcKeeRUE
Command: TRIM
Current settings: Projection=View, Edge=Extend
Select cutting edges ...
Select objects or <select all>: Specify opposite corner: 2 found
Select objects:
Select object to trim or shift-select to extend or
[Fence/Crossing/Project/Edge/eRase/Undo]:
After starting the TRIM command and selecting the cutting edges, does it remind you that you can use shift, as shown above in red?
Active Member
Message 6 of 7 (391 Views)
Re: Trim + Shift
03-14-2012 08:25 AM in reply to: nestly
Yes
Active Member
Message 7 of 7 (390 Views)
Re: Trim + Shift
03-14-2012 08:26 AM in reply to: CMcKeeRUE
my projection is set to UCS.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
