AutoCAD 2010/2011/2012
Member
JamesPomerich2603
Message 1 of 7 (19,451 Views)
Accepted Solution
Total Line Lengths / List command
19451 Views, 6 Replies
04-26-2011 06:57 AM
I have several large group of lines on different layers that I want to get a total length of each group.  I can highlight them all and use the list command but then I have to go through the text box and write down each line length and then add them up hoping I don't miss one.  Not to mention it's going to take a while because of the number of lines that I have.
Is there a way to just have autocad add up a group of lines and give a total line length summation or get it from the particular layer?
Just curious.
*Expert Elite*
3wood
Message 2 of 7 (19,447 Views)
Re: Total Line Lengths / List command
04-26-2011 07:10 AM in reply to: JamesPomerich2603
You can try ADDLINES.vlx
3wood
CAD KITS
Member
JamesPomerich2603
Message 3 of 7 (19,420 Views)
04-26-2011 09:33 AM in reply to: 3wood
that worked. Thank you!
Active Contributor
cado
Message 4 of 7 (19,379 Views)
04-27-2011 02:01 PM in reply to: JamesPomerich2603
you can use this..
Lot of cool stuff on DuctiSoft
Member
JamesPomerich2603
Message 5 of 7 (19,361 Views)
04-28-2011 05:33 AM in reply to: cado
Thanks - I'll check that out next time.
*Expert Elite*
rkmcswain
Message 6 of 7 (19,355 Views)
04-28-2011 06:10 AM in reply to: JamesPomerich2603
Another option is to use the DataExtraction command.
It does take a minute or so to initially set it up, but the advantage is that the total is updated automatically if any of the lines are modified, or new lines are added.
Member
JamesPomerich2603
Message 7 of 7 (19,342 Views)
04-28-2011 07:28 AM in reply to: rkmcswain
Good to know - that would be handy because it is something we update and change.
You are not logged in.
Announcements
    Come hangout with Autodesk Support Specialist and AutoCAD guru Volker Cocco, to learn about Precision Drafting: Object Snaps and Object Tracking on July 31 @ 11:00 AM PST.
    Click here for registration information!
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
