I am trying to install a custom toolbar on Autocad 2010. it is not a custom made toolbar from the options in autocad. this is a outside source custom toolbar. A person I work with added this to his autocad 2005 with no problem and works. He explained how he added it to his and I did the same but does not show up when I look in the toolbar dropdown.
Any help would be great.
in AutoCAD 2005 and lower, an MNC file loaded in AutoCAD creates an MNS file and all the 'secrets' your sender tried to hide reveal themselves. it's been like that since R2000 I believe, anyone with an old seat can try it and see.
ith later versions, you need the MNS file (most folks don't update their MNU so you might get an old version with that one) and you need to be able to understand what portions of it you need to access/load. You may also need their mnl file but you need to be careful: make sure you never overwrite any file you have with the same name. Ask your AutoCAD2005 friend to help you out.
Some light reading to help you with 'after' when you have an MNU or MNS file to understand the "portions" to copy over per my first reply:
http://www.lukewarmcoffee.com/cad/AUGI%20-%20MNU%20MNS%20MNR%20MNC%20MNX%20MNL%20or%20CUI.pdf
