AutoCAD 2010/2011/2012
Distinguished Contributor
XlhHarley
Message 1 of 11 (249 Views)
This may simple but...
249 Views, 10 Replies
11-30-2011 05:58 AM
I have a blocks that have multiple nodes on the same x,y axis but different Z points (elevations)
When I copy in the plan view, node to node, it picks what ever z node point it feels like.. Is there some simple thing I am missing that will allow me to keep - or force - my pick and copy point to a certain elevation?
Patchy
Message 2 of 11 (239 Views)
Re: This may simple but...
11-30-2011 06:26 AM in reply to: XlhHarley
Simple, because you have many Z nodes, use isometric view.
Use the right tools for the right job.
Product Support
luconceicao
Message 3 of 11 (194 Views)
12-02-2011 08:15 AM in reply to: XlhHarley
Maybe you could use point filters?
Not sure without seeing your drawing.
Cheers,
Luciane
Luciane Conceição
Product Support Specialist
XlhHarley
Message 4 of 11 (190 Views)
12-02-2011 08:32 AM in reply to: XlhHarley
Drawing attached for your look
Product Support
luconceicao
Message 5 of 11 (187 Views)
12-02-2011 08:58 AM in reply to: XlhHarley
I think it works:
Copy > select object > enter > type .z of 0 (for 0 elevation) > snap to the node when asked for XY and you have the first point in the XY position of the node, elevation 0.
Is this what you are looking for?
Cheers,
Luciane
___
Please click the button "Accept as Solution" if this suggestion resolves your issue.
XlhHarley
Message 6 of 11 (182 Views)
12-02-2011 09:08 AM in reply to: XlhHarley
Thanks for the reply
when i do this - it still walks
From the dwg - its much easier to work in plan view. This is a simple dwg. When I copy a group and go from one vertical pole to another. I am looking for the z elevation not to change. Right now , every time I copy from node to node, It snaps to the upper node on the vertical poles
Product Support
luconceicao
Message 7 of 11 (144 Views)
12-06-2011 09:20 AM in reply to: XlhHarley
It seems to work well for me, check the video:
http://screencast.com/t/0xyGTi12bio
Cheers,
Luciane
GrantsPirate
Message 8 of 11 (131 Views)
12-06-2011 10:22 AM in reply to: XlhHarley
First in Options, Drafting, check off "Replace Z value with current elevation",
Then in the drawing set the ELEVATION to the elevation you want to work in.
But it really is best to work in an iso view on a 3D model.
JGerth
Message 9 of 11 (123 Views)
12-06-2011 10:44 AM in reply to: XlhHarley
look into OSAPZ setvar, and using point filters, (.xy  .z)
XlhHarley
Message 10 of 11 (94 Views)
12-08-2011 06:49 AM in reply to: JGerth
Thanks  this works great
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
