Installation & Licensing
The system cannot open the device or file specified.
8 REPLIES 8
Message 1 of 9
15892 Views, 8 Replies
Starting Installations with Setup view screen the following error message:
C:\Users\Nombre\AppData\local\Temp\_AI4662.temp\x86\en-us\Components\adr2012\SetupDesignReview2012.msi
I need Help for solution.
8 REPLIES 8
Message 2 of 9
I have Laptop Toshiba Satellite A665-S6094 with i7 740QM, 4GB DDR3 1066, 640GB DDH, nvida 512MB video.
Message 3 of 9
allen_thompson
I am having the same problem installing Autocad Map3D 2013.
cpu is also trying to find setupdesignreview2013.msi.  Both file are located in my Temp folder???
Message 4 of 9
the path in Windows is limited in length. So try to move your installation-files into a folder in a higher hierarchy (e.g. C:\TEMP) and try to start the installer again.
Another options might be to first extract the EXE (at least it's a self-extracting zip that you can unzip manually) and start the setup.exe in it.
Good luck, - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Message 5 of 9
Rob.O
I know the original post from this thread is a couple of years old, but we just experienced this same issue so I thought I would share the solution (at least what worked here).
Be sure to turn off your anti-virus software prior to running the install.  In our case, Trend was protecting some of the folders required for the install.
I have seen this in the past with other anti-virus software, but this is the first time I have seen it happen with Trend.
Hope it helps!
Message 6 of 9
jgwinner
in reply to: Rob.O
Great post - that was my problem as well.  My Dad had installed Trend on my laptop.  I guess you can't get a virus if you can't do installs 🙂
== John ==
Message 7 of 9
JMcShane
in reply to: jgwinner
+1 on that!
I was installing IDSP 2017 and the same message came up.
Turning off Trend done the trick.
John
Message 8 of 9
Emmsleys
in reply to: JMcShane
Thanks for sharing that tip.
Sarah Emmsley
Technical Support Specialist
Message 9 of 9
in reply to: Emmsleys
I don't have that trend and the same issue still show up, I turned off my firewall and windows defender security center of windows 10, please help ?!!
Administrator Productivity
