I am trying to use our standard room name block in two new files from a client but it is not showing up the way it is supposed to. It looks like a totally different font. I have checked the text options box and it says it's "romans", just like it is supposed to, but it does not look right. It also does it with regular mtext that I copy in from another file. Once I change it back it looks right, but when I pull it in, it defaults to Romans and @arialunicode MS. I'm assuminng that's what the block is doing as well, but how do I fix that, and why is it doing it? Thanks!
Solved by Jay_B. Go to Solution.
Ok, so it fixed it automatically in one file but in the other it is still displaying everything as the @arialunicode one. Is there a quick way to get it to change all the text automatically or do I need to go in and edit each mtext individually?
The blocks are showing correctly but the mtext is still messed up.
