AutoCAD 2010/2011/2012
Active Contributor
Message 11 of 34 (819 Views)
Re: Text Annotations Don't Display
08-15-2011 06:49 AM in reply to: rick.hberg
Rick, we were only deleting the .pf file not the exe.  The .pf file is created as a cache to make all application loads after the first load faster.  The .exe is part of the WPF .NET 3.0 framework and needed for many applications and would never suggest the deletion of that file.   Hope this clears it up for you.
Mark LaBell, Jr.
BIM/CAD Technical Specialist
SSOE Group
www.linkedin.com/in/marklabelljr
Active Contributor
Message 12 of 34 (813 Views)
08-15-2011 10:03 AM in reply to: calvindale
Our MIS techs seemed to have fixed this issue by updating our machines to latest LANDesk client.
Valued Contributor
rick.hberg
Message 13 of 34 (811 Views)
08-15-2011 10:08 AM in reply to: mlabell
mlabell, thanks for the clarification.  That was the file I was looking at as per your first message. I got confused when trying to research the item online and ended up looking at the .exe descriptions.
Thanks again.
Civil 3D 2011
Windows 7 x64
Active Contributor
Message 14 of 34 (806 Views)
08-15-2011 10:48 AM in reply to: mlabell
I'm not sure this works yet as the problem is a bit random but has anyone tried this?
1) Click START > right click on COMPUTER > PROPERTIES.
2) Click ADVANCED SYSTEM SETTINGS
3) The System Properties dialog box opens and it should be on the ADVANCED tab already. If not, go there and click SETTINGS in the Performance section.
4) Select ADJUST FOR BEST PERFORMANCE and OK your way back out of all the screens.
Active Contributor
Message 15 of 34 (795 Views)
08-15-2011 12:47 PM in reply to: trucdang3750
I can recreate the issue at will and changing the theme as recommeneded does appear to fix the issue for the interim.  I havent run for a long enough time to call it good.  But there is still something that is completely underlying that theme shouldn't have anything to do with the issue.
This issue is only replicated on a Win 7 x64 computer when connected to an office network.  I can completely remove logon scripts, GPO and the issue does not happen.  Further, the issue does not happen when you logon to the computer locally without any office network connectivity.  Even tried logging into the computer via VPN to the office and the issue never happens.
It appears that disabling theme may band-aid the issue but there is a more underlying root cause with a Microsoft server componenet that is causing the issue to persist.
Mark LaBell, Jr.
SSOE Group
Active Contributor
Message 16 of 34 (775 Views)
08-18-2011 09:48 AM in reply to: mlabell
On of our users tried the "Adjust for best performance" setting and it did not work for him.  The only solution so far is to close out of AutoCAD and reopen several times until the test displays.
Valued Contributor
rick.hberg
Message 17 of 34 (751 Views)
08-22-2011 06:22 AM in reply to: trucdang3750
Has anyone had any additional luck with this one?  Or can anyone explain how to reproduce this on demand?  We are still having the same issues at randomly.  Close-reopen is still our best bet.  Thanks.
Civil 3D 2011
Windows 7 x64
Active Contributor
Message 18 of 34 (688 Views)
09-22-2011 03:43 PM in reply to: calvindale
@ Calvindale.  Which version of LANDesk did you upgrade to?
Active Contributor
Message 19 of 34 (687 Views)
09-22-2011 03:46 PM in reply to: trucdang3750
I forgot to mention that we tried updating our video card driver per the suggestion of Autodesk support.   We tried one recommended by Autodesk and a newer one that one of our IT guys found.  No luck.  Also tried uninstalling completely and then installing it again.  No luck.
Active Contributor
Message 20 of 34 (669 Views)
09-23-2011 04:35 AM in reply to: mlabell
Appears that this issue isn’t just an Autodesk issue but more of a Microsoft issue…
http://social.msdn.microsoft.com/Forums/en-US/wpf/thread/498984ed-5877-4602-a363-e34eadf88440
http://www.telerik.com/automated-testing-tools/support/documentation/user-guide/troubleshooting_guid...
I have been working with the Autodesk suppoprt team on this issue and they are now able to reprodcue at will based on windows prefetch file that I gave them.  Fingers crossed that something may get resolved soon.
Mark LaBell, Jr.
SSOE Group
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
