AutoCAD 2010/2011/2012
New Member
Rachel_Gee
Message 1 of 6 (1,451 Views)
Switching between Viewport and Layout
1451 Views, 5 Replies
02-18-2011 06:31 AM
Hi all
Ive got a problem that I'm hoping is easily solvable:
While on a layout tab, zoom in too far so that the viewport occupies the entire screen, double clicking into the viewport and reposition the drawing where needed but then meaning that I can no longer 'double click' outside the view port to switch back to the layout. I've had this happen on a few version's of autocad over the years (not only myself so I know I'm not the only one being dim!) and never found a 'quick fix' way out of it, other than using the 'undo' button all the way back to before the viewport became overzoomed - meaning loosing any work done, or closing without saving and restarting - again loosing work done.
Both of which seam over kill, there must surly be another way to switch betwen the two without double clicking outside the viewport??? Ive searched on the forum and the autocad help pages but could only find information on 'double clicking' which in this instance is somewhat usless.
Many thanks in advance :womanhappy:
Rachel Gordon
Valued Contributor
Message 2 of 6 (1,442 Views)
Re: Switching between Viewport and Layout
02-18-2011 07:17 AM in reply to: Rachel_Gee
You can switch between Paper and Model Space using the toggle/swictch on the statusbar. If it's not there put your cursor over the statusbar, right click and check on Paper/Model
Message 3 of 6 (1,439 Views)
02-18-2011 07:19 AM in reply to: Rachel_Gee
Pspace command
New Member
Rachel_Gee
Message 4 of 6 (1,437 Views)
02-18-2011 07:21 AM in reply to: Rachel_Gee
thankyou both, i knew there must be an easy way :smileyhappy:
*Expert Elite*
3wood
Message 5 of 6 (1,350 Views)
02-19-2011 02:48 AM in reply to: Rachel_Gee
You can also define a named View in Paper Space, then when you working in the model space of a viewport, you can use VIEW command to retrieve the saved view in the paper space.
3wood
CAD KITS
Distinguished Mentor
Moshe-A
Message 6 of 6 (1,339 Views)
02-19-2011 08:18 AM in reply to: Rachel_Gee
Rachel Shalom,
Another way to resolve this is to use Viewport Max buttom (in middle status line / vpmax command)
double click inside viewport then VPMAX then zoom in as much as you like
click again on Viewport Max buttom to zoom out back to layout
Moshe
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
