AutoCAD Forum
Sweep along Spline problem
5 REPLIES 5
Vasily_BC
4226 Views, 5 Replies
Looks like I missing something... I try to sweep along spline that made of elleptical arc and line.
Funny thing that I was able to create a solid few days ago by doing this method. Now I can't!
I tried even reload Autocad.
Any ideas? Thanks
5 REPLIES 5
Vasily_BC
in reply to: Vasily_BC
After all solid supposed to look like this but as a one object
steve216586
Works fine here. (see attached) Some more info would help diagnosis.
"No one can make you feel inferior without your consent. "-Eleanor Roosevelt
Vasily_BC
in reply to: steve216586
That's the problem, I don't do anything special. Maybe there is something with with UCS? Really don't know.
I run sweep, after click on an object and then on a path.
After Autocad shows:
Modeling Operation Error:
The sweep results in a self-intersecting body.
Unable to sweep 1 selected objects.
steve216586
I rotated the UCS 90 degrees about the x axis and started my object to sweep on the far right of the arc. That's all
Vasily_BC
Really don't know, but I exploded spline, merged it again and it worked with extrude.
Maybe it's end of the week, that's why)
”Boost
