AutoCAD 2010/2011/2012
*Expert Elite*
Message 11 of 12 (261 Views)
Re: Student Plant 3D - Complaint
02-08-2013 06:13 AM in reply to: hoodedmarcantonio
Did you install with UAC and anti-virus turned off?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
New Member
Message 12 of 12 (135 Views)
04-05-2013 02:41 AM in reply to: JDMather
Hi, I get exactly the same problem, I've got the 32bit student version and haven't been able to use it yet because I get this (see below) when I try to make a new drawing.
I found this explanation - http://www.lazcad.com/autocad-pid  -but can't figure out how to implement the solution, any ideas?
Dom
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
System.Runtime.InteropServices.COMException (0x80200033): Filer error
   at Autodesk.AutoCAD.Interop.AcadDocumentsClass.Add(Object TemplateName)
   at Autodesk.ProcessPower.ProjectManagerUI.frmNewDWG_Revised.CreateAndSaveNewDrawing()
   at Autodesk.ProcessPower.ProjectManagerUI.frmNewDWG_Revised.btnOK_Click(Object sender, EventArgs e)
   at System.Windows.Forms.Control.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ButtonBase.WndProc(Message& m)
   at System.Windows.Forms.Button.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.0.30319.296 (RTMGDR.030319-2900)
    CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
AdApplicationFrame
    Assembly Version: 0.0.0.0
    Win32 Version: 3.2.23.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/AdApplicationFrame.DLL
msvcm90
    Assembly Version: 9.0.30729.6161
    Win32 Version: 9.00.30729.6161
    CodeBase: file:///C:/WINDOWS/WinSxS/x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.6161_x-ww_31a54e43/msvcm90.dll
Acdbmgd
    Assembly Version: 18.2.0.0
    Win32 Version: 18.2.51.0.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/AcdbMgd.DLL
System
    Win32 Version: 4.0.30319.1001 built by: RTMGDR
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
AdWindows
    Assembly Version: 3.2.23.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/AdWindows.DLL
PresentationFramework
    Win32 Version: 4.0.30319.298
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
WindowsBase
    Win32 Version: 4.0.30319.298 built by: RTMGDR
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
PresentationCore
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
System.Xaml
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
System.Xml
    Win32 Version: 4.0.30319.233 built by: RTMGDR
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
PresentationFramework.Luna
    Win32 Version: 4.0.30319.1 built by: RTMRel
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Luna/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Luna.dll
System.Drawing
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Acmgd
    Win32 Version: 18.2.51.0.1
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/Acmgd.DLL
System.Core
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Configuration
    Win32 Version: 4.0.30319.1 (RTMRel.030319-0100)
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
AcWindows
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/AcWindows.DLL
AcCui
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/AcCui.DLL
PresentationFramework.Aero
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
AcWindows.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/en-US/AcWindows.resources.DLL
PnPDataLinks
    Assembly Version: 6.0.0.0
    Win32 Version: 6.0.39.00
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnPDataLinks.DLL
PnPCommonArx
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/pnpcommonarx.arx
PnPProjectManager
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnPProjectManager.arx
PnPProjectManagerMgd
    Assembly Version: 6.0.39.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnPProjectManagerMgd.DLL
PnPCommonMgd
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnPCommonMgd.DLL
PnIDMgdInternal
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnIDMgdInternal.DLL
PnIDUIMgd
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnIDUIMgd.DLL
PnPCIP
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnPCIP.DLL
PnIDCIP
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnIDCIP.DLL
PnPProjectManagerUI
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnPProjectManagerUI.DLL
PnPProjectManagerUI.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/en-US/PnPProjectManagerUI.resources.DLL
PnPRevisionCloud
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnPRevisionCloud.DLL
XDbReferenceManagerArx
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/XDbReferenceManagerArx.DLL
XDbReferenceManagerArx.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/en-US/XDbReferenceManagerArx.resources.DLL
PnIDMain
    CodeBase: file:///c:/program%20files/autodesk/autocad%20p%26id%202012%20-%20english/pnidmain.arx
ContextualTabSelectorRules
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/AcWindows.dll
PnIDWorkspace
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnIDWorkspace.DLL
    Win32 Version: 4.0.30319.1002 built by: RTMGDR
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
WindowsFormsIntegration
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
ManagedMC3
    Assembly Version: 5.8.0.0
    Win32 Version: 5.8.0.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/ManagedMC3.DLL
Accessibility
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
PnIDProjectPartsMgd
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnIDProjectPartsMgd.DLL
PnPDataObjects
    Assembly Version: 1.0.4206.15350
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnPDataObjects.DLL
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Autodesk.AutoCAD.Interop/18.2.0.0__eed84259d7cbf30b/Autodesk.AutoCAD.Interop.dll
Autodesk.AutoCAD.Interop.Common
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Autodesk.AutoCAD.Interop.Common/18.2.0.0__eed84259d7cbf30b/Autodesk.AutoCAD.Interop.Common.dll
ci0m01kq
jrb3xux4
PnP3dProjectPartsMgd
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnP3dProjectPartsMgd.DLL
PnP3dDataLinkManager
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnP3dDataLinkManager.DLL
PnP3dOrthoProjectPart
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnP3dOrthoProjectPart.DLL
044ymin1
System.Data
    Win32 Version: 4.0.30319.237 (RTMGDR.030319-2300)
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
PnPSQLiteEngine
    Assembly Version: 1.0.4206.15360
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnPSQLiteEngine.DLL
System.Data.SQLite
    Assembly Version: 1.0.65.0
    Win32 Version: 1.0.65.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/System.Data.SQLite.DLL
System.Transactions
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.Transactions/v4.0_4.0.0.0__b77a5c561934e089/System.Transactions.dll
Microsoft.VisualC
    Assembly Version: 10.0.0.0
    Win32 Version: 10.00.30319.01
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualC/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualC.dll
System.EnterpriseServices
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.EnterpriseServices/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
System.Numerics
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
vfomqhkf
thvcyghc
dyw3bgu1
arfmax0s
pnnlvcqx
PnP3dPartsRepository
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnP3dPartsRepository.DLL
PnP3dConnectionManager
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnP3dConnectionManager.DLL
nm0az2jw
kjfkodz3
v5dqncad
owb03bnj
032vecdh
vwhoqof5
PnIDProjectParts
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnIDProjectParts.Arx
PnIdGuiUtils
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnIdGuiUtils.DLL
PnIDGUIUtilMgd
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnIDGUIUtilMgd.DLL
PnPCommonUIMgdCs
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnPCommonUIMgdCs.DLL
PnPCommonUIMgd
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnPCommonUIMgd.DLL
AcTaskDialogs
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/AcTaskDialogs.DLL
AcTaskDialogs.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/en-US/AcTaskDialogs.resources.DLL
PnPWelcomeManager
    CodeBase: file:///c:/program%20files/autodesk/autocad%20p%26id%202012%20-%20english/pnpwelcomemanager.arx
PnPWelcome
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnPWelcome.DLL
PnPCommonDbxMgd
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnPCommonDbxMgd.DLL
PnPWelcome.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/en-US/PnPWelcome.resources.DLL
AcLayer
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/AcLayer.DLL
AcLayer.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/en-US/AcLayer.resources.DLL
AcButterflyExt
    Assembly Version: 1.0.0.23
    Win32 Version: 1.0.0.23
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/AcButterflyExt.DLL
AcButterflyExt.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/en-US/AcButterflyExt.resources.DLL
UIAutomationProvider
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
PnIDDwgValidation
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnIDDwgValidation.DLL
PnIDDwgValidation.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/en-US/PnIDDwgValidation.resources.DLL
PnPValidation
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnPValidation.DLL
frt5riuj
r02bf42j
pz4o2jql
54uwr5gd
uibmx0ak
00qe2h14
1g3ebi14
wntnl4u2
AcDialogToolTips
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/AcDialogToolTips.DLL
AcDialogToolTips.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/en-US/AcDialogToolTips.resources.DLL
AcCommandToolTips
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/AcCommandToolTips.DLL
AcCommandToolTips.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/en-US/AcCommandToolTips.resources.DLL
dyhhe42h
tmv0qkmv
3y33i4o3
3qavfmii
xxw3gve2
0dpcv55m
ge0ucpj5
ctyjohva
PnPDataGrid
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnPDataGrid.DLL
PnPDataGrid.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/en-US/PnPDataGrid.resources.DLL
************** JIT Debugging **************
Application does not support Windows Forms just-in-time (JIT)
debugging. Contact the application author for more
information.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
