Is there any way to increase the speed the 'move' part of the look function moves when using the steering wheel?
I really like the idea of being able to navigate fully using mouse & keyboard (kinda like an FPS really) use the mouse to look and the keyboard to move - however the move speed is painfully slow -almost undetectable. I believe is probably due to assumptions made on unit size - (I work in mm).
The steeringwheel settings dialogue allows some adjustment on the 'walk' speed, but that has no effect on the move speed when looking.
Any ideas anyone?
Solved by Laurent.Pallares. Go to Solution.
Hi dear,
There is a variable to make the scrol options set to fine tuning to have more precision when you scroll your steering wheel.
The variable to enable this option is: "ZOOMFACTOR"
Controls how much the magnification changes when the mouse wheel moves forward or backward.
Type: | Integer |
Saved in: | Registry |
Initial value: | 60 |
Accepts an integer between 3 and 100 as a valid value. The higher the number, the more the change.
Sorry the variable you mentioned has no effect on the walk speed when using the nav-wheel look feature. it does have an effect on the amount zoomed by the mousewheel, but that's not what I was after.
G
I see that your talking about another function:
"WALKFLYSETTINGS"
Could this article could be helpfull:
http://autodesk.blogs.com/between_the_lines/2009/01/learn-to-walk-and-fly-in-autocad.html
Best regards,
That's more like it.
It's odd but 3dwalk seems to be a different implementation of the walk feature on the nav wheel, the behavior of the mouse when panning/looking is preferable on the navwheel version as you are not constrained by the cursor position on the screen, however I do like the rest of the 3dwalk function, particularly the palette which displays an overview and co-ordinate data.
Thanks for the tip!
G
