AutoCAD 2010/2011/2012
Distinguished Contributor
Message 1 of 11 (6,113 Views)
Stacked fractions in Mtext
6113 Views, 10 Replies
05-05-2010 03:32 PM
How can I completely STOP this feature, unless I deliberately want it. I didn't see it in right click. And, of course, the wonderful "new" help feature is no help, It doesn't know what a stacked fraction is.
We heed the old help that actually WORKED!!!
*Dean Saadallah
Message 2 of 11 (6,116 Views)
Re: Stacked fractions in Mtext
05-05-2010 03:59 PM in reply to: RFUSE
Stacked Text, not fractions, although if you rely on the HTML help, it still
cannot find it.
That function has not changed in a very long time: create the stack,
highlight it, right-click, select Stack Properties, explore all of your
options.
If you want other 2011 Help options for now...
AutoCAD 2011 CHM-Based Help
http://usa.autodesk.com/adsk/servlet/ps/dl/item?id=15068206&siteID=123112&linkID=9240618
AutoCAD 2011 Help in PDF format
http://docs.autodesk.com/ACD/2011/ENU/pdfs/PDF%20Documentation.html
Dean Saadallah
http://LTisACAD.blogspot.com
Message 3 of 11 (6,116 Views)
05-06-2010 05:37 AM in reply to: RFUSE
Thanks Dean. No wonder I couldn't find it.
Valued Contributor
Message 4 of 11 (6,050 Views)
07-23-2010 02:34 PM in reply to: RFUSE
2011 is unable to save my settings for fraction text size (70% to preferred %). WHere do I go to save those settings?
In 2008 in mtext editor you can save them unders stackecd property.
Please help.
*Expert Elite*
pendean
Message 5 of 11 (6,025 Views)
07-26-2010 05:46 AM in reply to: Rosebm
Nothing has changed in 2011, same procedure noted about still applies in both programs.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
*Pro
Message 6 of 11 (6,014 Views)
07-26-2010 07:08 AM in reply to: pendean
There is a system variable called TSTACKSIZE which "controls the percentage of stacked text fraction height relative to selected text's current height. Valid values are from 25 to 125"
(saved in drawing)
Valued Contributor
Message 7 of 11 (5,982 Views)
07-26-2010 03:57 PM in reply to: murray-clack
Thank You MurrayClack!
If this exist on 2008, I never used this the mtext stack settings always worked for me.
Member
Message 8 of 11 (5,874 Views)
08-17-2010 08:52 AM in reply to: RFUSE
You have to select the stacked fraction first and then the new command line appear in the right click menu.  So you can select "Stack Propertie" and "Autostack" uncheck the appropriate box.
Once the Automatic Stack is disabled you can reactivate it.  Stack a fraction manually with the buttom in MText dialog box and proceed as described earlier.
Regards
Member
Message 9 of 11 (5,872 Views)
08-17-2010 08:59 AM in reply to: RFUSE
You have to stack the fraction manually in Mtext dialog box first, then you have to select the fraction and right click on it.  Now you can see the new "Stack propertie" command.  In the Stack Propertie dialog box select "Autostack" and check the appropriate box.
Regars
Member
Message 10 of 11 (4,882 Views)
07-12-2011 11:38 AM in reply to: clabbee
I noticed when it stacks dates you have to select a portion of it and right click to find the stack toggle.  This is crazy.  Is there some variable that get set when you enter the information in the dialogue box and hit don't ask again?  What if you change your mind?  Seems like it should be available in the ribbon or the properties areas.
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
