AutoCAD 2010/2011/2012
_Lemmy_
Message 11 of 24 (583 Views)
Re: Slow in opening .dwg from Window 2008 R2 server
03-07-2012 05:19 AM in reply to: PeopleWare
i dont think XP uses SMB2 to talk back to the server. SMB is a 2008/windows 7 issue
Active Member
alessio.ruggiero
Message 12 of 24 (581 Views)
03-07-2012 05:25 AM in reply to: _Lemmy_
After the changes made at server 2008 from SMB 2 to 1 and restarts,  the problem persists on XP machine.
_Lemmy_
Message 13 of 24 (577 Views)
03-07-2012 05:28 AM in reply to: alessio.ruggiero
then look at your drawings. it's most likely the source of your problems.
Active Member
alessio.ruggiero
Message 14 of 24 (573 Views)
03-07-2012 05:37 AM in reply to: _Lemmy_
I tried to purge and re-create the drawings and disable the signature validation options "c:\WINDOWS\system32\AcSignOpt.exe" but, I repeat,  problem persist on machines with xp 64 bit
_Lemmy_
Message 15 of 24 (570 Views)
03-07-2012 05:40 AM in reply to: alessio.ruggiero
how many users connect to the server?
Active Member
alessio.ruggiero
Message 16 of 24 (566 Views)
03-07-2012 05:51 AM in reply to: _Lemmy_
30 users with xp 64 bit (CAD machine)
70 users with xp 32 bit (Office machine) no problem
Active Member
Message 17 of 24 (562 Views)
03-07-2012 06:04 AM in reply to: alessio.ruggiero
We are using XP 32 bit and having trouble when we migrate the server to Windows 2008 R2.
I just changed the SMB setting on the server (disable SMB 2.0) but this didn't change a thing.
The other locations (about 85) where we use Windows 2003, we don't have performance issues.
The locations a from 20 to 450 workstations. The location where I am testen are about 10 concurrent users!
_Lemmy_
Message 18 of 24 (559 Views)
03-07-2012 06:05 AM in reply to: _Lemmy_
10 concurrent users should not create enough traffic to cause performance problems. I still think your issue is elsewhere
Active Member
Message 19 of 24 (555 Views)
03-07-2012 06:10 AM in reply to: _Lemmy_
But there are problems and we cannot stop Windows 2008 roll-out.
Hope someone have more tips. The problem is in Stabicad - Stabibase.
Active Member
alessio.ruggiero
Message 20 of 24 (549 Views)
03-07-2012 06:23 AM in reply to: PeopleWare
If I try to copy the same network folders, with for example 20 .dwg file, with same security permissions on a 2003 server, the problem on 64-bit machines has not present.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
