AutoCAD 2010/2011/2012
_Lemmy_
Message 11 of 24 (661 Views)
Re: Slow in opening .dwg from Window 2008 R2 server
03-07-2012 05:19 AM in reply to: PeopleWare
i dont think XP uses SMB2 to talk back to the server. SMB is a 2008/windows 7 issue
Active Member
alessio.ruggiero
Message 12 of 24 (659 Views)
03-07-2012 05:25 AM in reply to: _Lemmy_
After the changes made at server 2008 from SMB 2 to 1 and restarts,  the problem persists on XP machine.
_Lemmy_
Message 13 of 24 (655 Views)
03-07-2012 05:28 AM in reply to: alessio.ruggiero
then look at your drawings. it's most likely the source of your problems.
Active Member
alessio.ruggiero
Message 14 of 24 (651 Views)
03-07-2012 05:37 AM in reply to: _Lemmy_
I tried to purge and re-create the drawings and disable the signature validation options "c:\WINDOWS\system32\AcSignOpt.exe" but, I repeat,  problem persist on machines with xp 64 bit
_Lemmy_
Message 15 of 24 (648 Views)
03-07-2012 05:40 AM in reply to: alessio.ruggiero
how many users connect to the server?
Active Member
alessio.ruggiero
Message 16 of 24 (644 Views)
03-07-2012 05:51 AM in reply to: _Lemmy_
30 users with xp 64 bit (CAD machine)
70 users with xp 32 bit (Office machine) no problem
Active Member
PeopleWare
Message 17 of 24 (640 Views)
03-07-2012 06:04 AM in reply to: alessio.ruggiero
We are using XP 32 bit and having trouble when we migrate the server to Windows 2008 R2.
I just changed the SMB setting on the server (disable SMB 2.0) but this didn't change a thing.
The other locations (about 85) where we use Windows 2003, we don't have performance issues.
The locations a from 20 to 450 workstations. The location where I am testen are about 10 concurrent users!
_Lemmy_
Message 18 of 24 (637 Views)
03-07-2012 06:05 AM in reply to: _Lemmy_
10 concurrent users should not create enough traffic to cause performance problems. I still think your issue is elsewhere
Active Member
PeopleWare
Message 19 of 24 (633 Views)
03-07-2012 06:10 AM in reply to: _Lemmy_
But there are problems and we cannot stop Windows 2008 roll-out.
Hope someone have more tips. The problem is in Stabicad - Stabibase.
Active Member
alessio.ruggiero
Message 20 of 24 (627 Views)
03-07-2012 06:23 AM in reply to: PeopleWare
If I try to copy the same network folders, with for example 20 .dwg file, with same security permissions on a 2003 server, the problem on 64-bit machines has not present.
