I created a sheet set file using Acad2012 with overrides. Also I set the Acad2012 to save all file as a 2010 and lower.
If I try to use the sheet set file in a Acad2013, two things happen. First, in using the sheet set to create a PDF file (the size of the PDF sheet is set at 24X36) it shows the file cut like it's using an 11X17 sheet, but in Acad2012 the PDF file is okay. Second, once I use that sheet set file in Acad2013. I can't use the same sheet set file in Acad2012. It's like I have to create two sheet set files for the same project and is that possibly? I know trying to add the same DWG into another sheet set does not work. Is there a way around that also?
