AutoCAD 2010/2011/2012
Donald_the_Inventor
Message 1 of 3 (471 Views)
Shadeplot Render Option
471 Views, 2 Replies
12-29-2010 08:31 PM
I have setup a viewport in paperspace.  I have used the -vports command, in the shadeplot option it gives a Render option, and then a quality option, such a high, presentation, or custom, which sets the DPI higher.  I have tried various level options and still get whitewashed images within the rendered regeion.  Any hints, suggestions or fixes?
Message 2 of 3 (401 Views)
Re: Shadeplot Render Option
01-03-2011 01:16 PM in reply to: Donald_the_Inventor
What is the image supposed to look like?  Have you tried Visual Styles?
Donald_the_Inventor
Message 3 of 3 (331 Views)
01-18-2011 01:20 AM in reply to: Donald_the_Inventor
If you open the ploted image file you will see dimensions around a fuzzy white object.  The object is a simple profile of a surfaced solid with a wood grained texture on it, that renders fine in the model view.  Works fine if I use the "As Displayed" setting.  But it is only the 'realistic view' kind of cartoonish.  Attached is the same file rendered using the "As Displayed" setting.
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
