AutoCAD 2010/2011/2012
Message 1 of 2 (1,241 Views)
Setting 3DCONFIG Manual Tune Options In Command Line
1241 Views, 1 Replies
03-22-2012 08:18 AM
I am looking for a way to set a couple options in the Manual Tune window from the Performance Tuning window (3DCONIG Prompt). More specifically I want to be able to:
  1. Check what the setting for Enable hardware acceleration is (so it can be restored back)
  2. Set Enable hardware acceleration off
  3. Reduce the number of tessellations to cache
  4. Reduce both the Surfaces, and Curves tessellation
How would I do this from command line? My ultimate goal here is to run these commands in .NET.
*Expert Elite*
vladimir.michl
Message 2 of 2 (1,224 Views)
Re: Setting 3DCONFIG Manual Tune Options In Command Line
03-23-2012 01:12 AM in reply to: tracer123
You can set some of the acceleration parameters using the commandline version of 3DConfig: -3DCONFIG
We are using it in our TURBO utility - http://www.cadforum.cz/cadforum_en/switch-autocad-to-turbo-mode-tip7109
Other parameters can be set in the Registry - in HKCU....3DGS Configuration\\GSHEIDI10  (be careful when changing these values)
Vladimir Michl, www.cadstudio.cz
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
