AutoCAD 2010/2011/2012
Active Member
Message 1 of 4 (127 Views)
Selection window
127 Views, 3 Replies
06-08-2011 01:28 PM
Is there an easy way to align the selection window with an object?  Say, for instance, I have an object with many entities at 45 degrees closely situated next to other objects.  I want to select ONLY, the object(s) at 45 degrees without selecting the objects adjacent to them.
Is there a way to rotate the selection window?
Is there another way to do this?
Active Member
LightingDesignAlliance
Message 2 of 4 (121 Views)
Re: Selection window
06-08-2011 01:36 PM in reply to: lwittstock
You can use any of the following window functions within a command:
Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/P
revious/Undo/AUto/SIngle/SUbobject/Object
You probably want to use WP or CP
*Pro
nestly
Message 3 of 4 (115 Views)
06-08-2011 02:11 PM in reply to: lwittstock
As far as I know, you can't change the angle of the selection window, but you can easily align your view so the angled objects are horizonal or vertical having the same effect as rotating the selection window.
What you'll probably find more useful are the advanced selection options mentioned above.  To select the object(s) before starting a command, type SELECT at the command line, followed by one of the selection options "WPolygon" "CPolygon" "Fence" etc
http://www.youtube.com/watch?v=ciEP6gE7Jdc
Active Member
Message 4 of 4 (101 Views)
06-08-2011 05:25 PM in reply to: nestly
Thanks to both!!!  I will try the suggestions.
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
