AutoCAD 2010/2011/2012
Valued Contributor
tvcad
Message 1 of 9 (820 Views)
Selected Image Hides Underlying Geometry
820 Views, 8 Replies
01-11-2012 09:18 AM
When I grip-select an image, or pick it at the "select objects" prompt, the image hides all other geometry behind it. Troublesome when trying to fine-tune the image(png background) location relative to other entities.
Image transparency on, draworder back, monochrome, image @ 0'-0"Z.
Image looks fine until I pick it.
Simple toggle in 2011? Thanks
Acacd 2011, Win7 64
pendean
Message 2 of 9 (810 Views)
Re: Selected Image Hides Underlying Geometry
01-11-2012 10:29 AM in reply to: tvcad
When selected, the object becomes active and comes to the front: do you need to measure and move the object by actual distances instead of an eye-ball nudge?
Does moving all the other objects to the FRONT lessen the issue? Or the image at a small minus-Z distance so that it is truly under all the other objects?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Valued Contributor
tvcad
Message 3 of 9 (805 Views)
01-11-2012 10:46 AM in reply to: pendean
Thanks. I know I cant snap to the image contents, just eyeballing.
Problem is that I cannot see what I am eyeballing TO.
Moved image to a negative Z, no good.
Moving other objects to front does not help.
This issue is new in 2011. When image is selected, its contents disappear, and its frame becomes like a face or a wipeout.
Please see attached.
Valued Contributor
tvcad
Message 4 of 9 (796 Views)
01-11-2012 10:48 AM in reply to: tvcad
Sorry, meant the the contents (below) the image disappear
Distinguished Mentor
thepworth
Message 5 of 9 (792 Views)
01-11-2012 10:52 AM in reply to: tvcad
IF nothing else works...
go to paper space, put in 2 concurrent viewports for the same area (copy/paste with Shift-ctrl-c/-v for basepoint),
then you can freeze the image in the "top" viewport" with the linework....
a runaround but might help :smileysad:
C3D 2011
Intel Xeon E5630@2.53Ghz
NVIDA Quadro NVS420 Dual Monitor
12GB Ram / Win7 Professional 64bit SP1
Patchy
Message 6 of 9 (787 Views)
01-11-2012 10:58 AM in reply to: tvcad
Can you attach that part of the drawing and the image here. I like to see why it doesn't work for you.
Valued Contributor
tvcad
Message 7 of 9 (782 Views)
01-11-2012 11:14 AM in reply to: Patchy
Its not just THIS image. Its ANY image, including TIFFs.
Valued Contributor
Tudor_Timotin
Message 8 of 9 (641 Views)
11-23-2012 06:44 AM in reply to: tvcad
Just had the same problem
IMAGEHLT on 0 solved it for me
Maybe it helps,
Tudor
Valued Contributor
tvcad
Message 9 of 9 (564 Views)
01-09-2013 11:41 AM in reply to: Tudor_Timotin
Belated Thanks! That did it.
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
