AutoCAD Forum
Section of multi-view block
1 REPLY 1
alexander.garber
1096 Views, 1 Reply
hi again,
at my office we're working with 3D-Solid Objects and multi-view blocks.
now, it seems to me that creating a section / building elevation ist only possible for the 3D-objects and not for multi-view blocks.
it actually seems logical to me that it works that way - i just wanted to make sure if that is true. or maybe if i am missing something. or maybe if you can turn m-v blocks into solids?
or maybe someone knows a good work-around?
thanks alex
1 REPLY 1
Hi again, i found out eventually. Since noone was able to answer I thought it might be good to just write it down. It is possible to show multi-view blocks in sections and elevations. You just have to activate it. The simpliest way of doing that is via the Display Manager. Go to Manage / Display Manager / Representations by Objects / Multi-View Block References and just check for Elevation.
”Boost
