AutoCAD 2010/2011/2012
Active Member
JohnAlderson3838
Message 31 of 41 (551 Views)
Re: Screen Menu in 2012, screenboxes
02-02-2012 11:08 PM in reply to: jclong
Samsung monitor here, i7/ 24gb ram/ 2TB raid 10/ 120gb SSD/ Wacom Intuos 3 19x12
The wacom setup easily for acad2012.
My systems now 2 years old. The 2009/ 2010/2011 wacom drivers were pretty hairy for Win7 X64. The just released drivers actually seem bug free so far.
Active Contributor
jclong
Message 32 of 41 (513 Views)
03-14-2012 01:37 PM in reply to: JohnAlderson3838
" ....I'm on a 30" screen at 2560x1600, and the 35 rows would be lucky to be half the available height.  In the good 'ol days, of R8/9/10....."
John, I'm using the same size and resolution monitors and have now started working with ACAD 2012.  However, using the redefine ...  screenmenu routine as above, my screenmenu is only 26 rows and I see the screenboxes readonly confirms that number..
Have you or anyone else found a way around that?  And are you using your screen menu now?
I'm finding that a normal modeling session now is taking up to 3x longer without my custom menus.  I didn't realize just how much faster they were until now.
And has anyone substituted a pallet for the screen menu?  I'm starting the search to see if there is a way to use my old macros and switches in a different format..  But it all takes time and as long as there is still work to get paid for, it's difficult finding the time to dig in to the menu issues..
Active Contributor
LouderCAD
Message 33 of 41 (506 Views)
03-14-2012 01:56 PM in reply to: jclong
I use the screen menu every day all day along with the pull-down menus, the cursor menu, and occasionally the toolpalette. I do not use the ribbon at all. I've been customizing the menu since 1987 and release 9. I will miss the screen menu and I'm not sure how to replace it yet. I may investigate OpenDCL and modeless dialog boxes. AutoCAD toolpalettes offer some functionality but the ribbon just takes too much screen space away. I use very few toolbars.
Valued Mentor
tim.turner
Message 34 of 41 (505 Views)
03-14-2012 01:57 PM in reply to: jclong
After trying several locations I found that putting the ribbon on the right side where the old screen menu was located actually worked great for me, mainly because I keep layer palette, tool palette and properties palette all open at the left edge of the right monitor and the layer palette flys out as needed. (Make sure you get the PaletteAutoHideSpeed.exe and slow down the open time with a configuration like this or the layer palette will fly open covering the other two every time you mouse over.)
It did take some time but I got the Ribbon pretty customized so I only have to use a couple of tabs and I don't have to switch that much. You can put anything you are running now on the ribbon but like you say it takes time. The slowest part is getting the panels configured which would be SO much faster with a drag-and-drop functionality in the CUI editor (Autodesk?).
sanpo
Message 35 of 41 (471 Views)
04-07-2012 06:43 AM in reply to: LouderCAD
 It is an absolute pity that Autodesk is discontinuing one of their most used interfaces in AutoCAD. It was persistent and dynamic - best for data selection from lists. Panels do not serve these. Popo-up menus come-and-go.
Hope Autodesk decides not to discontinue it and provide a way to continue it. There are thousands of applications designed with screen menus. There is a resistance to migrate because of the set-back people expect in their businesses by upgrading.
I sincerely hope Autodesk offers some patch or switch to allow modifying CUIs with screen menus till they provide equivalent tool.
Active Member
JohnAlderson3838
Message 36 of 41 (461 Views)
04-08-2012 03:22 AM in reply to: sanpo
I decided to discontinue my subscription, as Autodesk is now actively making it harder to use Autocad.
sanpo
Message 37 of 41 (453 Views)
04-08-2012 08:40 AM in reply to: LouderCAD
Don't you think it is a clumsy solution? Once 2011 is upgraded to 2012 how often can we toggle?
New Member
bk304616
Message 38 of 41 (365 Views)
07-12-2012 08:19 PM in reply to: LouderCAD
My AutoCAD instructor hated AutoCAD with a passion.  He always said: "....dumb old, stupid old AutoCAD...." LOL.  Maybe doing stuff like this was why.
SteveChestnut
Message 39 of 41 (361 Views)
07-13-2012 05:26 AM in reply to: Steve_Johnson
Hello donande,
Just wanted to let you know that you can customize the ribbon and export it.
I use an enterprise.cuix to store all our customization.
I've created ribbon tabs and panels for our different types of drawings.
Some of our custom panels are used on multiple tabs.
Note that the first panel on every custom tab is "basics".
My users love the custom tabs.
I've attached a picture of what I'm talking about.
Hope you give them a try.
Good luck,
Steve
sanpo
Message 40 of 41 (346 Views)
07-13-2012 10:53 PM in reply to: LouderCAD
It is very easy to call screen-menus old-fashioned or out-dated and sound like one having the a best taste and being sophisticated. It is only ignorance of how powerful and simple the screen-menu interface is. No one undermines icons and even ribbons (provided Autodesk weeds out problems). These are definitely elegant and convenient methods of grouping and picking the commands.
Screen-menus still have a reason to stay as they offer facility to offer static lists of selection (say one has to select one of the design standards from a list of 30 to 50 standards). In spite of being static, one can write code to dynamically alter these static lists every time the application starts, there by giving ease of having the updatable lists every time. In such applications (which are not few in engineering), it is not necessary and rather counterproductive to have icons and graphics associated with these entries.
Panels are somewhat near but advantage of Screen-menus is that they work for all versions of AutoCAD while panel’s one version is not compatible with the other. Development and testing time for engineering applications is long. AutoCAD comes with a new version every year. With this scenario, the panel option is not worth considering as an alternative to Screen-menus.
In my personal opinion, Autodesk should continue with Screen-menus and re-introduce it in the legacy section.
You are not logged in.
    Come hangout with Autodesk Support Specialist and AutoCAD guru Volker Cocco, to learn about Precision Drafting: Object Snaps and Object Tracking on July 31 @ 11:00 AM PST.
    Click here for registration information!
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
