AutoCAD 2010/2011/2012
New Member
waleedmessouri
Message 1 of 5 (310 Views)
Scale
310 Views, 4 Replies
12-04-2012 10:55 PM
Hi
I hav an object with 5 sides as lines length are 10, 8, 5, 4 and 3 cm, I want to cut 1 cm from each side using the scale command or any other easier method. I mean I want to minimize the boundary of the object by 1 cm.
*Expert Elite*
Alfred.NESWADBA
Message 2 of 5 (288 Views)
Re: Scale
12-05-2012 12:52 AM in reply to: waleedmessouri
That are two different statements, do you want to reduce now every single segment by 1cm or the global length (all segments cumulated) should be reduced by 1cm.
For case 1: I would use grips to do that
For case 2: it's not defined here how this 1cm has to be splitted to each segment.
...or I don't understand something?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
New Member
waleedmessouri
Message 3 of 5 (257 Views)
Re: Scale
12-05-2012 08:23 AM in reply to: Alfred.NESWADBA
Thanks very much for your help. I mean all the boundry will be reduced by 1 cm. The shape boundries will come inside by 1 cm.
*Expert Elite*
Alfred.NESWADBA
Message 4 of 5 (253 Views)
Re: Scale
12-05-2012 08:31 AM in reply to: waleedmessouri
That might mean you want to reduce every segment by 1cm/5 = 2mm (you mentioned 5 segments) or should there be done something like an offset by an unknown distance so the boundary get's reduced by 1 cm?
Again not everything clear. Maybe you can create a sample drawing with a poly before and after modification?
At least if it's the offset-variant so that might fail if the polyline has a quite straight form.
- alfred -
Alfred NESWADBA
**Master
dmfrazier
Message 5 of 5 (237 Views)
Re: Scale
12-05-2012 01:49 PM in reply to: waleedmessouri
Sounds like a job for the OFFSET command.  (But I agree with Alfred that it is not exactly clear what you want.)  OFFSET (mind the options!) will copy objects a set perpendicular distance (the offset amount) from the original objects.
If OFFSET is indeed correct, be sure your lines (edges) are joined as a POLYLINE first, or you will have to TRIM the copies of each individual line to get your final new shape.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
