AutoCAD 2010/2011/2012
Member
john7267
Message 1 of 6 (1,943 Views)
Accepted Solution
Saving to an older version of AutoCAD
1943 Views, 5 Replies
05-06-2013 06:27 AM
 have two questions:
1: I currently am using AutoCAD 2011 is there any option to back save drawings to 2008?  I do not seem to have this choice.Only 2010 or 2007 or 2004.
2: If I upgrade to 2014 or 2013 will I have the option to back save to 2008?
John7267
*Expert Elite*
braudpat
Message 2 of 6 (1,938 Views)
Re: Saving to an older version of AutoCAD
05-06-2013 07:02 AM in reply to: john7267
Hello from France
Just a story of the DWG format :
DWG R11 was used by ACAR R11/R12
DWG R13 was used by ACAD R13
DWG R14 was used by ACAD R14
DWG2000 was used by ACAD 2000 , 2000i , 2002
DWG2004 was used by ACAD 2004 , 2005 , 2006
DWG2007 was used by ACAD 2007 , 2008 , 2009
DWG2010 was used by ACAD 2010 , 2011 , 2012
DWG2013 is used by ACAD 2013 & 2014
AutoCAD 2013/2014 can save to the DWG2007 format without any problem !
And as far as i know, you can go until DWG2000 ...
So go on ...
Bye, Pat
Bye, Pat
*Expert Elite*
Jay_B
Message 3 of 6 (1,939 Views)
05-06-2013 07:07 AM in reply to: john7267
"1: I currently am using AutoCAD 2011 is there any option to back save drawings to 2008?  I do not seem to have this choice.Only 2010 or 2007 or 2004.
The dwg file format changes roughly every three years.
 2008 is in the 2007 file format range (2007-2009) so when saving as a 2008 compatible drawing 2007 dwg option  is selected.
2: If I upgrade to 2014 or 2013 will I have the option to back save to 2008?"
Yes you will still have the option to save to the 2007 dwg file format.
Hope this helps.
Jay
C3D 2014 SP1
Win 7 Professional 64 Bit
*Expert Elite*
Charles_Shade
Message 4 of 6 (1,912 Views)
05-06-2013 12:41 PM in reply to: Jay_B
But be aware of Proxy Objects that may get lost in the translation.
Experiment with a plan or two before you roll out the change.
Download the Trial and see if you really want to know:
http://www.autodesk.com/products/autodesk-autocad/free-trial
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
Member
renny_chan22
Message 5 of 6 (1,639 Views)
09-11-2013 11:35 AM in reply to: Charles_Shade
So then how do I solve this problem : I'm currently using Autocad 2013 on my mac and when I open an Autocad file and try to save them to a 2010 version after I finish editing , I got this pop up . Kindly look at the attachment . So how do I solve this issue , or is there any other alternatives as I know that a 2013 dwg file  cannot be opened on an Autocad 2011 software .
Thanks in advance !
*Expert Elite*
dgorsman
Message 6 of 6 (1,633 Views)
09-11-2013 11:39 AM in reply to: renny_chan22
Thats a slightly different problem.  You can have different DWG file versions (R14, R2000, 2010, etc.) but you can also have objects inside the drawing which have an *object* version based on the software used to create them.  Note that objects can be data as well as drawing entities, so you won't necessarily see everything.  That software may not be supported in earlier versions of AutoCAD so while you can save the DWG file down to an earlier version the object content cannot be supported.
If you are going to fly by the seat of your pants, expect friction burns.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
