I am having a bit of an issue. I do my drawing in Autocad, then I print to a JPG pc3 file, so I have a jpg of the drawing. Our illustrator uses Powerpoint and when she inserts the jpg's into Powerpoint, all the lines in the drawing are not that dark and appear quite faint. What can I do to improve this?
Kev
Try checking Color, Grayscale, & Screening settings in your ctb file used to plot the drawing, also increase Lineweight for each color proportionally.
This is how the JPG's are turning out. I checked the lineweight and it is set at 0.25mm
Try increase the lineweight to 1mm instead of 0.25mm. You can adjust lineweight to suit powerpoint display
