AutoCAD 2010/2011/2012
New Member
w_sawyer2
Message 1 of 11 (2,604 Views)
SCALELISTEDIT dialog box not visible
2604 Views, 10 Replies
05-19-2011 10:23 AM
Anytime I try to add a custom scale either by selecting the "custom scale" option from the paperspace viewport scale menu or by entering the command SCALELISTEDIT manually, the dialog box doesn't appear.
It's not that the box isn't opening because all other buttons and functionality are restricted in AutoCAD until I hit escape to exit out of the command.  It's as if it's opening on a separate monitor, except it doesn't appear on my secondary monitor when I plug it in either.
Has anyone run into a similar issue?  Is there a command where I can manually add a custom scale or a property that I can change to force the box to be docked?
*Pro
Message 2 of 11 (2,594 Views)
Re: SCALELISTEDIT dialog box not visible
05-19-2011 11:50 AM in reply to: w_sawyer2
Woah - that's weird - I've never heard of that one before.
In the meantime, try using the command line version -SCALELISTEDIT (note the hyphen before the command name)
Active Contributor
Message 3 of 11 (2,502 Views)
07-14-2011 11:03 AM in reply to: murray-clack
Have same problem on dual monitor system. Thanks to murray-clack for workaround. But stell, i think autodesk have to pay more attention on dual monitors
Active Contributor
Message 4 of 11 (2,497 Views)
07-14-2011 11:18 AM in reply to: cadhelp
Ok, here is the solution.
type SCALELISTEDIT
then Alt+Space shortcut to window's main  menu - select Move
Use arrow keys to reposition the dialog.
It works on any  window that are not displayed for some reason on dual monitor systems.
New Member
Message 5 of 11 (2,098 Views)
04-23-2012 12:40 AM in reply to: cadhelp
I've tried this and the Dialogue box appeared - however every time I select add/edit the box freazes and I cannot proceed.
I'm working on Auocard LT 2011, please could someone give me direction?
Thank you
Active Member
ethomas
Message 6 of 11 (1,693 Views)
10-30-2012 12:13 PM in reply to: murray-clack
Has this ever been resolved?  i am running Civil 3D 2012 64 bit in Windows 7 with dual monitors and having the same problem.  Murray-clack's workaround worked for me, but what a headache to have to use the workaround.
Active Contributor
Message 7 of 11 (657 Views)
10-03-2013 09:12 AM in reply to: w_sawyer2
This happends if a dialog bounds location gets a negative value in the registery/profile.  You can edit the following registry by deleting them or change the negiteve value to 450 or something safe.  I deleted these keys from our custom ARG file so the error would not get pushed to new users.  Autocad will recreate the values the first time the dialog gets used.
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R18.2\ACAD-a002:409\Profiles\BASICAutoCAD2012\Dialogs\Autodesk.AutoCAD.ScaleList.ScaleListAdd] "Bounds"="-1301, 288, 298, 238"
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R18.2\ACAD-a002:409\Profiles\BASICAutoCAD2012\Dialogs\Autodesk.AutoCAD.ScaleList.ScaleListEdit] "Bounds"="-923, 334, 298, 238"
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R18.2\ACAD-a002:409\Profiles\BASICAutoCAD2012\Dialogs\Autodesk.AutoCAD.ScaleList.ScaleListForm] "Bounds"="-828, 290, 356, 345"
Mark
*Expert Elite*
braudpat
Message 8 of 11 (649 Views)
10-03-2013 11:00 AM in reply to: marknelson
Hello
+1 with MarkNelson
Did you change your graphic card ? or its Resolution ?
Did you switch between One Screen and Two Screens ?
The only safe solution can be to reset XY position of the dialog box concerned !
So follow the magic wand called MarkNelson !
Bye, Pat
Bye, Pat
Valued Mentor
Message 9 of 11 (633 Views)
10-04-2013 06:36 AM in reply to: w_sawyer2
So here is another possibility. The SCALELISTEDIT Display may be off screen. Try this. Enter SCALELISTEDIT, Enter.
Then at the same time push both the ALT key and the SPACE BAR, then release, push "M", release. Now with your arrow keys try moving up, down, left, or right until you see the Display. Just a thought. Read Y'all Later -KLYPH
Valued Mentor
Message 10 of 11 (627 Views)
10-04-2013 09:08 AM in reply to: KLYPHY
Opps. Don't push "enter" after pushing the "M".
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
