AutoCAD Forum
Rotated viewport results in distorted image
2 REPLIES 2
MREveretts
1658 Views, 2 Replies
Help please - Any viewport rotation other than a multiple of 90 results in distorted image.  On the atttached pdf, the top vp is rotated 90 degrees (image looks the same as it does in model space - good), the bottom is rotated 135 (image is very light, almost a negative in places - bad).
I attached the geotiffs in dwg1 using mapinsert with no adjustment other than some fade, and am referencing dwg1 into dwg2.  Plotting from dwg2.
I initially rotated the all the views with alignspace, when I noticed teh problem.  I've since tried creating a new vp and just rotating/clipping it, same result.
Any ideas?
Thanks!
MRE
2 REPLIES 2
pendean
in reply to: MREveretts
There is no MAPINSERT command in AutoCAD: are you in the wrong forum? Civil and MAP have dedicated forums.
ALIGNSPACE may not be the best tool either (for plain AutoCAD anyway): DVIEW comamnd's TWIST option or UCS command inside the viewport can rotate the contents quite well.
MREveretts
in reply to: pendean
I guess I am in the wrong forum - I was thinking this one would be general.  I'll post my question in Civil.  Thanks & sorry
”Boost
