AutoCAD 2010/2011/2012
Message 1 of 21 (5,208 Views)
Ribbon disappeared, how do I get it back
5208 Views, 20 Replies
08-27-2009 03:37 PM
I've been trying to incorporate my menus and toolbars into the ribbon environment. I skipped acad 09 so this hasn't been fun. I used the transfer feature in the cui environment to get everything I wanted. I go to 2d environment to check that everything is there and it appears to be there. I load my cui and I get my icons and menus but no ribbon. I have a big message that says, "The Ribbon does not have any tabs or panels currently loaded." I type ribbon to load, but nothing.
I've now messed with this enough that even with the base acad.cuix file I still don't have the ribbons.
What have I done wrong and how can I fix it?
THX
Member
jparaz
Message 2 of 21 (5,208 Views)
Re: Ribbon disappeared, how do I get it back
08-27-2009 04:01 PM in reply to: 10231971
Try this. Type menu in your command line and under support folder click on acad.
Good luck.
markdoel
Message 3 of 21 (5,208 Views)
08-27-2009 05:41 PM in reply to: 10231971
change your workspace back to the initial setup workspace and you should get the original populated ribbon back
Message 4 of 21 (5,208 Views)
08-28-2009 06:04 AM in reply to: 10231971
I've unloaded my cuix file and reloaded the original acad.cuix that you're referring to and the ribbon is gone.
Message 5 of 21 (5,208 Views)
08-28-2009 06:05 AM in reply to: 10231971
> {quote:title=markdoel wrote:}{quote}
I think I've done that by reloaded the base acad.cuix.
Also, I type ribbon to load it but that doesn't make it come back on the screen.
**Master
dmfrazier
Message 6 of 21 (5,208 Views)
08-28-2009 06:10 AM in reply to: 10231971
I think the part that's missing is the Workspace. Go back to your customized CUI and make sure you select (turn on) the ribbon tabs you want in the workspace(s) you will be using.
Message 7 of 21 (5,208 Views)
08-28-2009 08:52 AM in reply to: 10231971
If I look under workspaces, 2d, then over on customize workspace on the right it lists the quick access toolbar, toolbars, menues, palettes, and ribbon tabs. If I click ribbon tabs it lists Home-2D, insert, annotate, parametric, view-2d, manage, output. Shouldn't those particular ribbons appear on my screen?
**Master
dmfrazier
Message 8 of 21 (5,208 Views)
08-28-2009 10:14 AM in reply to: 10231971
Yes, if that workspace is set current.
Message 9 of 21 (5,208 Views)
08-28-2009 10:42 AM in reply to: 10231971
> {quote:title=dmfrazier wrote:}{quote}
Any thoughts or suggestions on why they aren't appearing in spite of them showing up in that workspace?
**Master
dmfrazier
Message 10 of 21 (5,208 Views)
08-28-2009 11:37 AM in reply to: 10231971
Maybe your CUI is missing the Ribbon Panels?
Announcements
Need installation help?
