AutoCAD 2010/2011/2012
JasonRuhl
Message 1 of 5 (473 Views)
Ribbon Tab Display Problem
473 Views, 4 Replies
11-28-2011 09:46 AM
Is anyone else getting this problem: Menus and Tabs do not refrest properly. This happes when I plot preview or sometimes when I Alt-Tab
AutoCad 2012 SP1 / Windows 7 64 bit
Patchy
Message 2 of 5 (472 Views)
Re: Ribbon Tab Display Problem
11-28-2011 09:49 AM in reply to: JasonRuhl
Autocad doesn't like Aerotheme that much, you can try other themes and see if it'll help.
JasonRuhl
Message 3 of 5 (452 Views)
11-30-2011 11:05 PM in reply to: Patchy
That seems to have solved it, thanks.
- Jason
Valued Contributor
Message 4 of 5 (409 Views)
12-16-2011 02:32 AM in reply to: JasonRuhl
I've brought this issue up way back in the 2009 version, when Autodesk starting using the Windows Presentation Framework.
It does not state in any AutoCAD literature that they do not support the Windows Aero theme! If fact, some of AutoCAD's features (i.e. task bar preview) rely on the Aero being enabled!
I have raised a support ticket with Autodesk and they haven’t got a clue why it happens, stating that they can't re-produce the issue, which I find hard to believe.
I personally think it's a graphics card issue. I use an ATI FirePro which is certified by Autodesk. But have used other cards and this issue seems to be less apparent.
JasonRuhl
Message 5 of 5 (398 Views)
12-16-2011 08:50 AM in reply to: JasonRuhl
Thanks Tony; I tried it without Aerio and it seemed to fix the problem, but then decided I prefer Aeriol; so switched back and am just dealing with this problem. Sigh.
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
