AutoCAD 2010/2011/2012
Valued Contributor
Spiritshifterus
Message 1 of 6 (434 Views)
Request for help in creating a linetype
434 Views, 5 Replies
10-23-2012 08:27 AM
Good morning, all.
I am trying to create a new linetype. It is a simple linetype, made up of a continuous chain of capsules that I've attached here. I understand that linetypes require shape files and line definition files. However, AutoCAD isn't even telling me how to create the shape file(s) I need to begin making the linetype.
The capsule is .12 units long at its widest, and will need to connect end-to-end. Would someone please help me? Thank you.
Chris Martin
Janet2009
Message 2 of 6 (427 Views)
Re: Request for help in creating a linetype
10-23-2012 08:52 AM in reply to: Spiritshifterus
Use Express Tools to make shape then make linetype
Valued Contributor
Spiritshifterus
Message 3 of 6 (402 Views)
10-23-2012 11:41 AM in reply to: Janet2009
Dear Janet2009,
Thank you for creating the linetype for me. I also found the Express Tools that you spoke of, and thus I was able to recreate what you had made. No wonder I couldn't find any AutoCAD help on the subject, since those tasks were Express'es.
Have a good day.
Chris Martin
Distinguished Contributor
chad38
Message 4 of 6 (103 Views)
12-04-2013 12:06 PM in reply to: Spiritshifterus
Hello, I am attempting to set up a new linetype, and I came across this thread and am using the info contained herein to do so. I had to modify my autocad install to include "express tools"(fingers crossed that this is the express tools that was mentioned), but now I am unable to figure out where to even access express tools. It's not showing up anywhere in the start menu, I've looked all around the UI in autocad mechanical.......
Am I missing something here? Please help. It would be very appreciated. Thanks
Cybertron PC
Intel Core i5-3470 CPU @ 3.20 GHz 3.60 GHz
16.0 GB RAM
Windows 7 Professional 64 Bit
3D Connexion Space Pilot
Inventor Professional 2014
Autocad Mechanical 2014
Patchy
Message 5 of 6 (96 Views)
12-04-2013 12:24 PM in reply to: chad38
Type in:
EXPRESSMENU    or       MENULOAD, do you see EXPRESS in there?
If nothing, you need to put the DVD in the tray and install it.
chad38
Message 6 of 6 (89 Views)
12-04-2013 01:09 PM in reply to: Patchy
Not sure if MENULOAD would have worked, but I found in another thread instruction to enter CUILOAD, and loaded a file from express folder, and it gave me the express tools user interface. However the function to create a new linetype kept giving me an "unknown command" error. Then I entered APPLOAD and pick a few thingys and after doing so, Express Tools was up and running. Thanks for your response, however!
Cybertron PC
16.0 GB RAM
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
