AutoCAD 2010/2011/2012
Member
tkoshurba
Message 1 of 6 (7,375 Views)
Accepted Solution
Rendering Background Colour
7375 Views, 5 Replies
08-03-2011 05:36 AM
Wondering if someone can help....I am using AutoCAD 2012 and rendering works great except I am having difficulty changing the background colour to white. I have followed some previous posts where it was suggested to change the environment fog ON and colour to white, background ON. I have also changed the 3D parellell projection display background to white.
After doing this it did indeed start to render with a white background however now the image is coming out a solid shade of light grey?? Any suggestions?
Product Support
luconceicao
Message 2 of 6 (7,337 Views)
Re: Rendering Background Colour
08-08-2011 06:32 AM in reply to: tkoshurba
Did you try creating a large white object that works as a background?
That could be an alternative.
Hope it helps,
Luciane
Luciane Conceicao
Product Support Specialist
Autodesk, Inc.
Member
tkoshurba
Message 3 of 6 (7,306 Views)
08-11-2011 03:58 AM in reply to: luconceicao
Thanks for the response however creating a large white object in the background does not work as the lighting changes the shading of this image. Cannot seem to get a true white background? Any other suggestions?
Product Support
luconceicao
Message 4 of 6 (7,297 Views)
08-11-2011 08:29 AM in reply to: tkoshurba
Here is another tip from my colleague: to set the render background color, first use the VIEW command to create a named view with the desired background, and then make it current.
Attached is a sample file.
Hope this helps,
Luciane
Member
tkoshurba
Message 5 of 6 (7,283 Views)
08-12-2011 06:50 AM in reply to: luconceicao
Thanks alot! Works great
Moderator
Discussion_Admin
Message 6 of 6 (6,697 Views)
11-08-2011 08:50 PM in reply to: tkoshurba
We split your post in to its own topic in the AutoCAD 2012 forum
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
