AutoCAD 2010/2011/2012
Distinguished Contributor
Message 1 of 9 (2,521 Views)
Accepted Solution
Remove wipeouts
2521 Views, 8 Replies
12-19-2012 08:08 AM
Is there an easy way to remove all the wipeouts in a drawing without deleting the entities they are attached to?
I have hundreds in some drawings, so I am trying to do a mass editing through lisp, but it won't remove just the wipeout, the text grouped with it gets deleted too. Any ideas?
Valued Contributor
Message 2 of 9 (2,515 Views)
Re: Remove wipeouts
12-19-2012 08:39 AM in reply to: cjneper
Use combination Ctrl+H (or Pickstyle set to zero) then delete the wipeout.
Message 3 of 9 (2,508 Views)
Re: Remove wipeouts
12-19-2012 08:52 AM in reply to: cjneper
Perfect!  Thank you.
Member
whorton-DK
Message 4 of 9 (2,491 Views)
Re: Remove wipeouts
12-19-2012 10:19 AM in reply to: cjneper
Here is a small lisp routine I picked up somewhere which removes wipeouts
(defun c:gowipe (/ b)
 (setvar "pickstyle" 0)
 (setq b (ssget "x" '((0 . "wipeout"))))
 (command "._erase" b "")
Valued Contributor
Message 5 of 9 (2,469 Views)
Re: Remove wipeouts
12-19-2012 12:50 PM in reply to: whorton-DK
Lisp is good but for something not doing everyday like deleting wipeouts
Qselect, image, DELETE key wouldn't be that difficult.
Valued Contributor
Message 6 of 9 (2,432 Views)
Re: Remove wipeouts
12-20-2012 01:35 PM in reply to: cjneper
As easy as using the QSELECT command see image above and hitting the delete key after hitting ok on that dialog box. However if the wipeouts are embedded in blocks they won't be erased.
*Expert Elite*
pendean
Message 7 of 9 (2,425 Views)
Re: Remove wipeouts
12-20-2012 01:56 PM in reply to: Dave_S
Let' count the ways....
SELECTSIMILAR, found in a right-click or typed: simplest of them all. Everyone forget?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
area51visitor
Message 8 of 9 (2,331 Views)
Re: Remove wipeouts
03-04-2013 02:21 AM in reply to: cjneper
wlhorton... You wouldn't happen to be in the vegas area would ya? Lol...that's the routine I wrote (exactly).
- Brian
"Very funny, Scotty. Now beam down my clothes."
greg.battin
Message 9 of 9 (2,289 Views)
Re: Remove wipeouts
03-05-2013 07:48 AM in reply to: cjneper
I just thought that I'd add one more tip in case someone can't select a wipeout to delete:
Use TRFRAMES in the command line.
This is a Toggle which means that simply running the command will either tuen it on or off. This toggle allows you to select Wipeout frames to be erased.
Also shown [HERE]
~Greg
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
