AutoCAD 2010/2011/2012
Active Member
adam_parkes
Message 1 of 4 (92 Views)
Relative Pathing Help
92 Views, 3 Replies
07-02-2012 07:40 AM
I am trying to change my Xrefs from full pathing to relative pathing.
If the file i am trying to xref is located at the following location
\\hfg.int\departments\Production\06 HA\01 Structural\Fabrication Engineering\Drawing Office\Previous Projects\A11001
What do i put for the file path for it to be relative pathed?
Thanks in advance
Adam
*Expert Elite*
Alfred.NESWADBA
Message 2 of 4 (69 Views)
Re: Relative Pathing Help
07-03-2012 03:02 AM in reply to: adam_parkes
>> If the file i am trying to xref is located at the following location[...]
We can't tell you that as long as we don't know the path your current dwg-file is stored. (That's the way "relativ" works, you need at least two informations to declare a relation between them).
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
Active Member
adam_parkes
Message 3 of 4 (67 Views)
07-03-2012 03:06 AM in reply to: adam_parkes
The dwg file is currently saved in the same location, but once the drawing has been issued it will be saved at the location specified with \issued drawings at the end.
*Expert Elite*
Alfred.NESWADBA
Message 4 of 4 (62 Views)
07-03-2012 03:09 AM in reply to: adam_parkes
In that case the XRef-Name is
.\A11001.dwg
(if A11001.dwg is the name of the XRef)
- alfred -
Alfred NESWADBA
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
