AutoCAD Forum
Reg. Annation Scaling Is Not Supported In AutoCAD Mechnical Symbols
5 REPLIES 5
dhimant.bhensdadia
363 Views, 5 Replies
While opening the AutoCAD file which I have, I am gettinbg the error as shown in the Snapshot.
Please reply as sson as possible its urgent...
5 REPLIES 5
as this is specific to AutoCAD Mechanical you should ask in the forum for Mechanical >>>here<<<.
Good luck, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
I think you have to check/redraw all the annonative dimmensions.
Does the DIMSTYLE command (does Acad Mech have DIMSTYLE ?) show anno dim's ?
Than change them to your favorite dim style. And check the values.
Actually in my drawing there are no dimension.
Only block are there, so is it the issue because of Dimension ?
Maybe all the dimmensions where ANNO dim's and you dont see them because of this error, or do you have a PDF or a print out of the origional drawing to check the dimensions.
Or install the free DwgTrueviewer to open that drawing and see the ANNO dim's yourself !
If there are no dimensions in your drawing it can't be a problem with dimensions.
The message in your screenshot says: ...contains objects supporting Annotation Scaling ..., so that might be blocks (and attributes), text, mtext, dimension, hatch.
Again: I guess people using Mechanical might have the better ideas of how to get rid of it, here is just plain AutoCAD discussed (and at least I have no idea about how Mechanical works with scales).
- alfred -
Alfred NESWADBA
”Boost
