While opening the AutoCAD file which I have, I am gettinbg the error as shown in the Snapshot.
Please reply as sson as possible its urgent...
as this is specific to AutoCAD Mechanical you should ask in the forum for Mechanical >>>here<<<.
Good luck, - alfred -
I think you have to check/redraw all the annonative dimmensions.
Does the DIMSTYLE command (does Acad Mech have DIMSTYLE ?) show anno dim's ?
Than change them to your favorite dim style. And check the values.
>> so is it the issue because of Dimension
If there are no dimensions in your drawing it can't be a problem with dimensions.
The message in your screenshot says: ...contains objects supporting Annotation Scaling ..., so that might be blocks (and attributes), text, mtext, dimension, hatch.
Again: I guess people using Mechanical might have the better ideas of how to get rid of it, here is just plain AutoCAD discussed (and at least I have no idea about how Mechanical works with scales).
- alfred -
