AutoCAD 2010/2011/2012
Active Contributor
etp1017
Message 1 of 3 (1,838 Views)
Accepted Solution
Redefining Blocks with Attributes
1838 Views, 2 Replies
04-12-2012 08:30 AM
I have a large amout of P&ID drawings that have blocks with attributes. One of the blocks is missing an attribute field that I need so I recreated the block using the same name and added the missing attribute. When I reinsert the block and say "yes" to updating the block's definition within one of my P&ID drawings everything seems fine excepot when I try to edit the block to fill in that field. The newly added attribute doesn't show up but when I right click one of these blocks and select Block Editor the new attribute field does shows up so the redefine did work I just can't use that attribute. Is this a bug in AutoCAD? Any ideas as to how I can use this attribute?
Thanks in advance :smileyhappy:
Johneng
Message 2 of 3 (1,832 Views)
Re: Redefining Blocks with Attributes
04-12-2012 09:11 AM in reply to: etp1017
Did you run the ATTSYNC command after you redefined the block?
Active Contributor
etp1017
Message 3 of 3 (1,822 Views)
04-12-2012 09:45 AM in reply to: Johneng
That worked!! Thanks :smileyhappy:
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
