AutoCAD 2010/2011/2012
JeffRusson6157
Message 1 of 10 (2,806 Views)
Raster image transparency
2806 Views, 9 Replies
03-20-2012 08:28 AM
Hi all
I have a small raster image (png) xrefed to an Autocad 2012 dwg.  The image is on its own layer and the transparency of the layer is set to 60%.
When I select TPY the image displays correctly on the screen (i.e. semi-transparent).  When I tick Plot transparency in the Plot dialog box and send the plot to our HP Designjet 800 the raster image prints exactly as I want (semi-transparent).
However when  I use the Autodesk pdf writer (Dwg to pdf) the resulting pdf does not have the semi transparent appearance and the raster image appears in all its brilliant colour even though it displays correctly (i.e. semi-transparent) in Print Preview. And, yes, I have ticked the Plot transparency box before sening it to the pdf writer. Other autocad entities such as plines which are semi transparent are fine, its only the raster image that seems to lose its semi-transparent quality.
Any ideas?
Many thanks.
Jeff
Product Support
luconceicao
Message 2 of 10 (2,783 Views)
Re: Raster image transparency
03-22-2012 09:01 AM in reply to: JeffRusson6157
Hi Jeff,
Do you mind uploading your DWG and PNG files?
Cheers,
Luciane
Luciane Conceição
Product Support Specialist
Autodesk, Inc.
JeffRusson6157
Message 3 of 10 (2,780 Views)
03-22-2012 09:35 AM in reply to: luconceicao
Product Support
luconceicao
Message 4 of 10 (2,772 Views)
03-22-2012 10:18 AM in reply to: JeffRusson6157
Hi Jeff,
Thanks for the files, I can reproduce it.
I am checking what is going on and get back to you soon.
Cheers,
Luciane
*Expert Elite*
pendean
Message 5 of 10 (2,767 Views)
03-22-2012 10:32 AM in reply to: JeffRusson6157
Does it do the same if you plot to a 3rd party PDF driver?
What about the DWG to DWF.PC3 file?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Product Support
luconceicao
Message 6 of 10 (2,764 Views)
03-22-2012 10:34 AM in reply to: pendean
I tried DWF and it's the same :smileysad:
JeffRusson6157
Message 7 of 10 (2,748 Views)
03-23-2012 02:00 AM in reply to: JeffRusson6157
Both CutePdf & PDFCreator maintain the transparency into the pdf.
Jeff
Product Support
luconceicao
Message 8 of 10 (2,700 Views)
04-19-2012 08:35 AM in reply to: JeffRusson6157
Hi Jeff,
Our developers are aware of the issue and it should be addressed in a future release of the product.
Thanks for letting us know.
Cheers,
Luciane
Active Member
jenniferhoskens
Message 9 of 10 (2,664 Views)
05-01-2012 05:01 PM in reply to: JeffRusson6157
I just had this same problem occur in AutoCAD 2013.  It is not fixed.
Thank you,
Jennifer Hoskens
CAD-1, Inc.
Product Support
luconceicao
Message 10 of 10 (2,649 Views)
05-02-2012 06:39 AM in reply to: jenniferhoskens
Sorry for the confusion, when I wrote the last reply AutoCAD 2013 had already been developed.
Thanks for your patience on this matter.
Cheers,
Luciane
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
