Im currently working with AutoCAD Civil 3D and noticed my profile is giving me random major vertical grid lines in my profile. I've completely deleted and re-created a new alignment and cut a new profile from the new alignement and still having the same problem. I've attached a couple of screenshots of the problem I'm having. Let me know if more information is needed to fix this problem.
Solved by Alfred.NESWADBA. Go to Solution.
welcome @forums.autodesk.com!
There is a special forum about Civil3D >>>here<<<, so it might make sense to place the question there again when the response here is not enough.
To your issue: Look to the profileview-style, tab "Display" and look if one of those two options are set to visible:
a) grid on alignment points
b) grid on sections
(sorry, if that are not the correct words translated as I don't have an English Civil3D)
If they are ON try to switch them OFF.
It might also be possible, to have that grid-like lines from bands or profile-labeling, remove bands and labeling (just for test) to see if/when these lines disappear.
HTH, - alfred -
