AutoCAD 2010/2011/2012
Patchy
Message 11 of 21 (1,603 Views)
Re: Random commands when fast mouse clicking
04-19-2011 11:21 AM in reply to: cmoore
It's a small bug, the size of a goliath beetle?
Product Support
Message 12 of 21 (1,563 Views)
05-03-2011 08:00 AM in reply to: dkenny
This behavior has been reported when the 'Use shortcut menus in drawing area' checkbox is unchecked.  To avoid the behavior, make sure that checkbox is checked.  If you wish to use the right-click primarily as ENTER/last command, click the 'Right-click customization' button, check the box for 'Time-sensitive right-click', and set the time to a higher number (2000, for example).  With that time setting, a shortcut menu would only come up after holding the right-click for 2 seconds.
Zac Travis
Member
tom_g86
Message 13 of 21 (1,495 Views)
05-24-2011 04:01 PM in reply to: Patchy
is there been a solution for the issue yet?
Member
tom_g86
Message 14 of 21 (1,491 Views)
05-24-2011 04:16 PM in reply to: tom_g86
... Other than that soloution above as that does work for me but it limits other things. I would have thought this would be something that would be a priority to fix. There are already 3 people at my work who will not use 2012 for this reason.
pendean
Message 15 of 21 (1,471 Views)
05-25-2011 07:11 AM in reply to: tom_g86
This forum is not the spot to ask for fixes: if you are on subscription, try harassing them there about it and hope a few hundred other users join in with the exact need.
If it is in the works, sign up for beta testing and get the inside scoop on future dealings and help influence future development.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Member
tom_g86
Message 16 of 21 (1,445 Views)
05-30-2011 11:07 PM in reply to: pendean
no need to be so rude, but thanks for pointing me in some direction
Member
Message 17 of 21 (1,377 Views)
06-27-2011 04:18 PM in reply to: tom_g86
I have been having this issue for a few weeks now. Thought I was going crazy. Happy to say I can delay that a bit longer. Problem now is something has happened to one of my files. Annotative blocks with text. They have all disappeared. They are still there, but cannot be seen. Obviously some system variable has been turned off. Any thoughts?
Opened the file in 2010 and in 2010 and 2012 on a different computer. Nothing.
After a days work I don't want to go back to the overnight backup.
Why can't these things happen at the start of the day.
Rossco
Member
Message 18 of 21 (1,371 Views)
06-27-2011 05:10 PM in reply to: rosscopeeco
My randomness turned off ATTDIS.
Generally I get a dialogue box so they are obvious.
This time was command line and I did not notice the change.
Beware of mystery random commands
Rossco
New Member
travo
Message 19 of 21 (1,316 Views)
07-22-2011 07:27 AM in reply to: rosscopeeco
I've been getting the right click problem too, after much googling I've found there's a new variable in 2012 for 'pickdrag', when this is set to '2' I get the right click problem, I've now set it to '0' which is the original setting for previous releases of Autocad and right click so far seems to be back to normal with no frustrating random commands.
Message 20 of 21 (947 Views)
04-02-2012 12:06 PM in reply to: travo
PickDrag-0 fixed my problems... thanks for posting...
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
