AutoCAD 2010/2011/2012
Valued Contributor
Spiritshifterus
Message 1 of 8 (432 Views)
Punched-out region question
432 Views, 7 Replies
01-10-2013 08:21 AM
Good morning, all.
I've never tried this in AutoCAD before, so that is why I've come to the experts here for help. I would like to create a simple rectangular area with a circle in its center. When this area is hatched, the circle is hollowed out. Furthermore, I'd like to have this to insert into a block for stretch action manipulation. Is this possible with AutoCAD 2010?
Thank you all.
Chris Martin
Alfred.NESWADBA
Message 2 of 8 (426 Views)
Re: Punched-out region question
01-10-2013 09:05 AM in reply to: Spiritshifterus
should be possible, haven't you tried it?
- alfred -
Alfred NESWADBA
Valued Contributor
Spiritshifterus
Message 3 of 8 (424 Views)
01-10-2013 09:11 AM in reply to: Alfred.NESWADBA
I have tried the Region command, but only for a few moments. And each time I tried, the command created two regions (the rectangle, and the circle). These remained separate to themselves; I could not figure out how to combine them, especially since the two elements do not intersect at any point.
Thank you.
Chris Martin
Alfred.NESWADBA
Message 4 of 8 (419 Views)
01-10-2013 09:19 AM in reply to: Spiritshifterus
Don't use region, use command _RECTANG for rectangle as polyline, then draw a circle and last but not least create the hatch.
- alfred -
Alfred NESWADBA
Valued Contributor
Spiritshifterus
Message 5 of 8 (416 Views)
01-10-2013 09:26 AM in reply to: Alfred.NESWADBA
Pardon me, sir, but I feel that you misunderstand what I am asking about.
I need to display a solidly filled rectangle area, and if the rectangle was a piece of paper, the circle would be a punched-out hole in its center. Wipeouts can do this, but only for linear polylines (no arcs). That is why I am asking about regions.
Chris Martin
Alfred.NESWADBA
Message 6 of 8 (406 Views)
01-10-2013 10:05 AM in reply to: Spiritshifterus
if so then sorry, but I give it an additional try.
If that is also wrong, then at least it helps that you can then describe what you don't like here.
- alfred -
Alfred NESWADBA
New Member
sancdub
Message 7 of 8 (397 Views)
01-10-2013 11:09 AM in reply to: Spiritshifterus
That is your idea?
Valued Contributor
Spiritshifterus
Message 8 of 8 (372 Views)
01-11-2013 07:40 AM in reply to: Alfred.NESWADBA
Dear Mr. Neswadba,
I took a look at your file. Thank you for it. I managed to get close to what you had before I began this thread. It appeared that I was not properly grabbing points & handling parameters when I dealt with the hatching. I have now accepted your thread as the solution, and you have my thanks.
Chris Martin
(A note to User sancdub: you were also on the same track as Mr. Neswadba and I. Thank you for your input also.)
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
