Solved by jessica.t. Go to Solution.
Hello Nando,
I'm sorry to see that you're experiencing this error however this is somewhat of a common issue so we have quite a bit of material on how to troubleshoot:
Please following the suggestions in the above threads to help troubleshoot your AutoCAD error. If the issue persists please respond to this post with further information including your hardware specifications and file sizes that you work with.
Thank you!
